3DScifieric's Klingon D7
scifiericscifieric1122 Posts: 1,497Member
edited April 2019 in Work in Progress #1
Finally took the plunge and started on a new starship. All being built in Blender 3D. The windows and ports are all just plugs for now as the blueprints are off on the placement and number of ports. I want to move them around until they look like they are a little closer to the placement of the original model components.
Thanks for looking in.
Post edited by Guerrilla on
Lizzy777wolfmanRekkertMadKoiFish
  • ViperViper1686 Posts: 717Administrator
    Looks very nice and clean so far :)
    scifieric
    Viper wrote: »
    Thank you, Viper!
  • Lizzy777Lizzy7771264 PNWPosts: 757Member
    Looks pretty smooth. Are you going to modify it with some extra detailing, or go with the classic D-7?
    scifieric
    Absolutely beautiful start! I’ll be following this!
    scifieric
    Lizzy777 wrote: »
    The answer is probably a mix. I really, REALLY want it to look like the classic D-7. But, I keep wanting to add some detailing, including lights.
    Thank you!
    Lizzy777
  • trekkitrekki947 Posts: 1,400Member
    Very nice mesh and so clean , =)
    scifieric
    scifieric wrote: »
    I added lights and disruptor turrets to the hull on mine. I don't remember if they were on the film model, but I think I found them on some blueprints. Compared to the rest of the ship, they can seem tiny and easy to miss. I also added a simple shuttle bay between the impulse engines.
    scifieric
    trekki wrote: »
    Thank you!
    Lizzy777 wrote: »
    I see you kept the multi-toned paint job too! Nice work!
    Lizzy777
    scifieric wrote: »
    Thanks! I'm looking forward to seeing yours progress. Have you seen the D7 ship reveal on Star Trek: Discovery yet? The more recent episode (Season 2, episode 12) showed a skewed 3/4 view from the rear that revealed quite a bit of detail on the reworked design.
    Someone on reddit captured a screen from that episode.
    scifieric
  • MadKoiFishMadKoiFish9797 Posts: 5,323Member
    edited April 2019 #11
    1080p cap for those wanting more pixels.
    https://madkoifish.files.wordpress.com/2019/04/std-d7-01.jpg
    Post edited by MadKoiFish on
    Lizzy777scifieric
    Lizzy777 wrote: »
    Yeah, Madkoifish shared the image on my website. They've greebled up the old design and added lots of JJ Abrams lights and flares. Hm.
    MadKoiFish wrote: »
    Thank you, Madkoifish!
    A very small amount of progress. A new neck, and starting to set the outlines for the main body. The bottom is harder than I thought.
    Lizzy777
    scifieric wrote: »
    I think I know which section you're talking about. I had trouble with that compound curve in the center-rear on the underside. Still, progress is progress!
    scifieric
    Are you doing via subdvisions? Should be fairly simple to get the shape right. Like the progress so far :)
    scifieric
    Viper wrote: »
    Yes I am. I need to break out my Klingon plastic model and more carefully examine the underside of the primary hull.
    Thank you!
