3DThe Enterprise E again - Obligitory Beauty Shot :)
VK08VK083 Posts: 0Member
edited November 2012 in Finished Work #1
Once again Dave's E with better lighting ;)
Post edited by VK08 on
tbg.jpg 148.3K
    Lighting looks good, the warp nacelles are still the only thing that really stick out to me...
    AMD Ryzen 9 5900X
  • BlueNeumannBlueNeumann631 Posts: 1,287Member
    I keep thinking that the E is so small... it's shots like this that remind me how big it actually is on the inside.
  • JMoneyJMoney189 Posts: 127Member
    I agree with Chris2005, lighting is very nice, but the warp nacelles and bussard collectors look off to me.
    Other then those two little things, great picture!
    JMoney
  • VK08VK083 Posts: 0Member
    JMoney wrote: »
    JMoney
    I'll ask IRML about that, seeing as he set the surfaces..
    VK08 wrote: »
    It could just be the lack of glow. I'm not sure about Lightwave, but in 3dsmax the glow materials look strange until you activate the glare output shader, then it looks great.
    Jmoney
    JMoney wrote: »
    Jmoney
    I used to use the built in glow, now I add the glow effects afterward... after seeing how good it looks when Tobias does it, I decided to do the same thing, and it's true, it's a lot better and you do have more control over the effect without having to re-render it all over again...
    AMD Ryzen 9 5900X
    JMoney wrote: »
    Jmoney
    One needs to activate the glow (in the image processing panel) or one of the corona/bloom shaders. IIRC, IRML comps these in afterwards.
    This is beautiful, but IMO, the lighting is just too dark... it shrouds too much of the model's nice detailing. Personally, I'd up the lighting level a bit.
  • DevilmanDevilman0 Posts: 0Member
    Excellent work!
  • overseerfxoverseerfx0 Posts: 0Member
    I think the overall scene lighting is exceptionally well done!
    Two suggestions from my end to make the ship "pop more" in the scene; for one, increase the nacelle glow. Even if it tends towards bright blue, it would look much better (in my opinion) and you could then add an area light between the nacelles to light a little bit of the hull. Also maybe increase the light strength of the windows facing the viewer. Since they're in the shadow, they would show much brighter.
    That would most likely both be a little bit of postwork though. Still, the overall lighting is mesmerizing!
