Hello again, sorry I don't use forums super regularly! At the start of the pandemic I started to make a Star Wars space battle animation and dropped off (
old thread here). In the time since then I've gotten a lot better at a variety of things, and only my low poly TIE fighter model is really up to my current standards. That was also before Mandalorian Season 2 came out, so there's been lots of SW inspiration since.
So now I'm working on a new SW project: a narrated animation fairly inspired By ECHenry's ship videos (and Howard Day, Angelos Karderinis, Skyforge, and other talented SW fan artists work), just flying around and exploring a medium sized imperial ship, the Gladiator class Star Destroyer. So I've reigned in the complexity by taking away the space battle aspect and ramped up the amount of models needed. I've been working on a LOT of assets, making everything myself because I enjoy the modeling/texturing parts. So I'm going to dump a lot of stuff here and update periodically. Everything is WIP. The assets are all pretty low poly / realtime ready because my hardware's not great.
Animation will start with a lambda shuttle dropping out of hyperspace. I have a
test animation of that.
We'll get some shots of the lambda approaching the hangar and landing
Some shots flying over the star destroyer... It's important to me that I can fly right into/out of the hangar without having to cut to a separate high detail model of just a small section of the ship, I like continuous shots.
The Gladiator class is a 600m long ship from the old '80s droids cartoon, recanonized through more recent appearances like the Armada game. I don't love their design for it and might take some cues from The Mandalorian's light cruiser. It's between that and a real star destroyer in size. I have only roughly blocked it out, and photobashed some possible ideas. The SD and light cruiser here are just official photos, not my models or anything.
The armada one has small hangars on the sides connected to the main flight deck, but the original cartoon version did not. Instead I will maybe add a very small hangar on the back for a TIE shuttle (the kind of ship
Captain Needa took to the Executor in ESB. A fan design for it was canonized with the TIE Fighter Owner's Workshop Manual book that I'll mostly follow.)
We'll maybe fly over the bridge (I don't know if I want to do a detailed bridge interior because then I need realistic looking humans...) follow a TIE shuttle leaving that hangar, and also have a look inside a laser cannon gun deck in the side trench of the ship, based on the ones seen on the death star in ANH, with death star gunners and stormtroopers and a mouse droid. (the dirt here is also over the top and not well-placed)
I haven't finished the stormtrooper models yet but here's his blaster:
I may also have a local ship and a couple of alien crew members visiting. I feel like one of the benefits of the gladiator would be impressing remote systems with a hangar large enough to park your ship inside, as opposed to the arquitens light cruiser or many smaller ships where you have to dock with them. I've been working on some alien models so I may use one of those. And a couple R4 droid colorschemes, the two on the left are based on imperial astromechs seen in the movies on the death stars.
So... I have a lot of stuff done, but also a lot to go. And again, everything is very low poly, between like 1000 and 10,000 tris for each asset. Details are textured on in Substance Painter, primarily by drawing a height map and then using procedural layer masks, no modeling any panels. Not for any good reason, sometimes it would be faster to just model and bake a mask or bake a height map for some of this stuff. But I'm kind of enjoying this workflow, it's kind of simple and meditative and satisfying. (Except for that pa'lowick alien above with the droids, that was a somewhat high detail sculpt in Blender and then retopology in Maya. Haven't rigged it, don't know if I will use it for this.)
Sorry it's a big post, I'm basically just throwing every Star Wars thing I've got into one big scene. Hopefully something nice comes out of it!
Here is a small test of a tiling texture for just the wide flat areas of the Gladiator hull (I think I might have the normals inverted...), as well as a basic camera move just showing the relative size and positions of things.
(Higher quality link)
And an early start on the TIE Shuttle and on the 'Death Star Gunner'
I'm also going to have a low-detail interior for the TIE shuttle, just to be seen from the outside. Here is a comparison of that (untextured, unfinished) with my TIE model, which is my oldest model I still consider good enough to use. Definitely makes a difference!
That sounds like a healthy attitude. Seems like your models aren't the only inspiring thing in here.
The cockpit definitely adds realism to the TIE, regardless how low poly it might be. Are you planning to build some for your other ships as well? They sure would benefit from it. Especially the Lambda shuttle, since it has such a wide window.
You know, I really wasn't planning to until your comment... I decided to try one out. This one's a bit tricky because in the movies / even in the Mandalorian, the lambda shuttle glass is 100% opaque. I made a couple of tests, one without tinted glass (and a glitch where the background doesn't show thru the glass correctly), one with tinted glass, and neither are right yet.
I think I'll probably tint the glass darker, but also increase the brightness of the interior material, so that you still get a hint of the very low poly forms in there. But right now it's too clear, especially when you see the wing through the glass. Maybe adding pilots will help too. Still, I've already done the hard part, I'll get it looking right soon.
I loved all that you showed us. Please, keep posting!
And here is an extremely small sculpt for an imperial officer to be standing behind the pilot in there, also something I can reuse in windows of the star destroyer.
And how the officer turned out, around 600 tris. TIE pilots will be next at this level of detail, for this and for the TIE shuttle.
Didn't get a ton done this weekend, but I am close to finishing the Zeta shuttle's textures, and also modeled and quickly textured an interior for it. This model really isn't meant to hold up even as close as the lambda, but even though the cockpit is extremely simple, that added depth will really help it out in moving camera shots.
If you don't want to blast the whole cockpit with light, what about a single additional light behind the pilot, not strong enough to effect the entire cockpit but strong enough to give him a bit contrast?
For now, this weekend I cut out the windows and made an interior for my TIE fighter. The exterior is a couple years old and was never meant to be seen up close, and isn't up to my current level of detail or texturing style. BUT, it still works pretty well, so I'll probably keep leaving it alone.
Higher quality link
And here is what the interior model looks like in substance painter viewport screenshots. Not super accurate, not super inaccurate.
Very small update: I got a little closer to blocking out the final shape for the gladiator-class star destroyer, updated the scene lighting a bit and added the planet from that hyperspace shot.
Thanks! It kind of is. I found a NASA satellite photo of a dust storm and did some photoshop to it (mainly the spherize filter). Unfortunately it's not high res enough to fill the frame, especially because spherize exaggerates the size of the center, so I can only have it as a distant planet and not recreate SW planet shots.
Busy weekend, so that's all for now!
