How to Build the USS Enterprise in Blender 3D
scifiericscifieric1096 Posts: 1,472Member
Hello everyone!
A long, LONG time ago, I made a tutorial on How to Build the USS Enterprise in TrueSpace 3D. Now here are the first seven videos in How to Build the USS Enterprise in Blender 3D:
*Edited*
01 Intro to Tutorial
https://youtu.be/apgTyq89zKs
02 Saucer Tutorial: Splines, Curves, and the Spin Tool
https://youtu.be/YVzgrYd8gy4
03 Saucer Windows and the Mirror Tool
https://youtu.be/P0Lr8-Z4Xgc
04 Making the Lower Saucer Windows
https://youtu.be/1sgmz4qpzPY
05 Making the Lower Saucer "Triangles"
https://youtu.be/7ubQTX_WEr4
06 Making the BC Deck (two ways!) and the Bridge
https://youtu.be/uShcbOWt6Jc
07 Making the Lower Saucer Sensor and Platform
https://youtu.be/aoKki_C21Mo
08 Linear Accelerator
https://youtu.be/AxwxECvixTo
09 Impulse Engines
https://youtu.be/Zx6prW26qZI
10 Forward Cutout and Running Lights
https://youtu.be/VFTdpW4rq9c
*End of Edit*
These first seven cover the saucer section, bridge, BC deck, windows, and lower saucer sensor and the sensor platform.
Later videos will also cover the impulse engines and the linear accelerator before moving on to the neck, the engineering section, the warp engines and the warp engine pylons.
This is not for someone who wants something done quickly. I show examples, sometimes multiple ways of doing something, reference images, and talk about the series and the models.
The first seven alone are well over five hours of video. But you will learn how to create a spline using verts, extrusions, and curves. You'll learn how to convert a mesh to a curve and a curve to a mesh. You'll learn how to create "drill plugs" for windows and how to use booleans.
I show you how to set up your environment inside Blender 3D, where to get blueprints and how to set them up inside your work area.
We modify UV spheres to create the BC deck and then I also show you how to "box model" a better BC Deck.
I talk about quads, tri's, verts, edges, origins, and faces.
This tutorial does not cover optimization of models. This is only to show the rudimentary tools and skills necessary to make a model that you can render that looks vaguely like the USS Enterprise from the original television series.
This is really for the beginner in Blender, or maybe someone who hasn't modeled anything before, or of course, for anyone who wants to learn how to make their own USS Enterprise!
Thanks for looking in. (I know, these are LONG videos!)
Guerrillaxiaorobear
