Hello,
i postet a long while ago my first ship, didn't work out, got frustrated and didn't post for a long time. New Job, move etc. Long time no time for Blender.
Now i started again and under some mysterious circumstances the Oberth Class became the first project which seems to go the way i want to. I think she got lucky because during her initial process it made kinda click in my head how modeling needs to be approaced to work for me.
So i decided its time for the first glimpse of here to show to others. She is far away from beeing finished but its a start i really like.
Update 1: Added Impuls Engines and lower View details and started detailing aft section
regards
Rizzo
Ha, tell me about it. Trying to figure out the right modeling technique for years now, and am frustrated on a regular base. It's only now that I slowly get the feeling I am on the right track. Would you like to tell me a little bit about your modeling approach? Mabey I can pick up one or two things.
Your Oberth Is looking great so far. It's a very fascinating design and quite a challenge I imagine.
I would like to share my Ideas, if you share yours ;-)
I learned a few bullet points that are true for me
1. Subdivide every problem that one can't solve as much as its necassary to be solvable. Meaning as much separate objects as necassary. My 1st tries had the idea to make the entire ship out of one block....its not managable, at least for me.
2. It must not be 100% right...is just needs to look that way. So a perfect mesh is not necassary to get the result ones want
3. Paper......i have a block of paper in front of me to understand basic structures before i start. I deleted meshes so often beause of simple mess up which could be solved if i would have drawn them up front on paper.
4. It must not be 100% according to image. At least for my purpose i don't need to be 100% accurate to the reference image. As its some sort of art, it allows for interpretation :-D. The block on the back of the ship is different from the series and all images i saw up until now...its my interpretation its not wrong....
5. Don't try to repair meshes which are to messed up...delete try again...the result is cleaner.
That's the few things i learned.
But even after hours the results may not be satisfactory.....
panels for example are a great nemesis to me.....i tried a lot on the saucer section on this weekend i still don't know if this looks good or not.....or if i should leave the paneling and try to solve it with a texture....
You are right these panels do look a bit strange. From what I can tell from screenshots the filming miniature didn't had panels on the saucer section. So maybe this design indeed works better without them.
What you could try though is to intrude the gridlines instead of extrude the panels and add a un-tiled ring around the upper edge. Perhaps this will make the panels appear a bit more subtle.
I'm afraid I can't share much.
Actually I was about to write a comment, but it took me longer than anticipated (basically because english isn't my native-language) and I'm a bit in a hurry right now. So maybe in one of the next evenings or the weekend. We will see.
I can offer one point of constructive criticism regarding the grid on the saucer. When you are modeling a grid, always cut in the middle of a face and never at the edges. When you cut in the middle of the faces, it preserves the curve of the larger surface. When you cut at the edges, it exaggerates the differences between the panels and interrupts the curve of the overall form.
As the Oberth shall be part of a shipyard picture (in the long distant future :cool:) i made this container. It will be part of the Workbees floating around the shipyard.
On this i will now try myself in therms of shading and lighting and this stuff i have no clue about
