New Project starting today with Doug Drexler and Robert Bolivar. We were yapping last week about things we'd like to see, based upon comments from the Enterprise campaign, and one that i came up with to redo and make "more better" was the USS Enterprise J from the episode "Azati Prime"
Since all Doug did was a base mesh with some textures, there's no real substance to it, so here is where we are at, making a full, high resolution model of it for rendering and other things.
Robert wrote up a brief history of the class, which is now officially "UNIVERSE CLASS" So join us as we bring this ship to life
By the beginning of the 26th century, Starfleet had re-embraced its original philosophy of exploration after several decades of hardships that plagued many of its member worlds.
Within the first 35 years, a new breed of Starship was commissioned and built. The U.S.S. Universe was the first of these massive 2 mile long ships that was designed to be multi-generational exploration mini civilization within itself. A sophisticated Artificial Intelligence, based on Dr. Noonien Soong's positronic network, helped maintain the newly designed computer system needed to run such a large ship. Its engines incorporated a new form of quantum slipstream drive (QSD) allowing it to travel faster and further than any human had ever gone.
During the ships initial mission, while under attack from an unknown species, the A.I. took a calculated risk and purposely caused a slight imbalance in the QSD allowing the ship to cross into another dimension entirely thereby escaping harm. The crew found that by utilizing this imbalance they were able to reconfigure the propulsion system into the justifiably dubbed Transdimensional Slipstream Drive (TSD). By A“piggybackingA†through nearby dimensions, the U.S.S. Universe was able to explore areas thought totally unreachable.
The reports that came back to Starfleet Command were rife with concerns. The QSD shortcuts were not always successful and it was soon realized that in order to safely use this new form of propulsion, a proper map of the nearby dimensions was needed. Starfleet sped up the timetable on the two other Universe class ships currently under construction and quickly commissioned a fourth.
The second ship to leave Spacedock was the latest in the long line of proud ships, the U.S.S. Enterprise. The NCC 1701-J was commissioned in 2552 to much fanfare and celebration.
Like the great seagoing vessels centuries before, each of these ships set out in a different direction to chart the unknown. The Enterprise J, proudest of the line, has set out on humankinds greatest endeavor.
I second that, a more detailed version of this model could be an amazing thing.
Also, that's a pretty cool backstory, and it could also explain the war with the sphere-builders, as they originate from another dimension.
It carries its own time ship? Nice. What other ships/shuttles does it carry?
@Sean YOu betcha, that's the idea here, make the ship to the point that it can hold up next to the rest of the line.. You should see the nacelle sketches
Stay tuned.
I sure would love to see the sketches. hopefully one day we can work on a ship together. Go to town on this baby.
I'd love to see some orthos of it. I'm sure Doug would have on his blog, but that's not around anymore, at least not officially.
My theory would be that if it's a generational ship, with people spending that much time on board, they might want to have the ability to allow as much natural light as possible in when it's available, to simulate an entire "outdoor" area.
Then if it's too dark, artificial lighting.
Or maybe it was a quickly put together model to be shown for 5 seconds on a TV show, and they really didn't have the time to put that much thought into it. I mean, look at all of the scale issues the Defiant has, and that was a hero ship!
There are some window groups on the primary hull that are as "big as the Defiant" inside those areas, are virtual cities, lakes, buildings, universities, starfleet academy, shopping, eating, etc... kinda like the ring ship from BSG. That's kind of why it has smaller support ships to go out on missions..
That being said, I'm glad this ship is being fleshed out as it deserves some love. I'm curious about those nacelle sketches
Frankly to see a 2 mile long ship in it's entirely you'd have be a good distance back from it so a those windows may just be tight groups or a large number of windows that look like individual windows.
I don't envy you texturing 2 miles of Starship
It's called "We have not designed the ancillary craft yet so we are taking a really bad shortcut to make the areas work" It will in the end probably be something that resembles a very early stage Wells.. But I'm nowhere near that yet, I'm still musing over the primary warp nacelles this morning.
Funny... While it might look flimsy, if one takes into consideration that these belong to a two-mile ship, all of the sudden they don't look so fragile anymore...
More J fleshing out.. nothing so concrete yet that it's done.. :P
Sorry to hear things aren't going so well for you today.
I can't help but wonder if Enterprise-J was going to be the Congo class (not TOS' Kongo) with a bit of a secondary hull to it.
Archer and daniels were in a curved section of hull well below the saucer, so that they could see the underside of the saucer hull above them.
If Enterprise J is flat-bottomed, this would not be possible...
--unless there was a zeppelin type cloud car underneath, or a free flying pod held in place due to field effect alone, as the segmented ships in the TV remake of DUNE or the mecha travel conveyences at the end of A.I.
I love the flying keel seen here. Combine this with the Congo, and you will have a great side view as well.
http://www.scifi-meshes.com/forums/showthread.php?75876-26th-Century-Designs
The wide stance reminds me of the ship in this psuedo-documentary of the future:
http://www.amazon.com/Planetary-Traveler-Nathan-House/dp/157252152X
Truly, the warp effect as seen from inside the JJprise should only have ben used for ENT-J, as if it is more fully submerged in subspace.
Actually here this may explain it better: bottom view (no detailing yet, it's all still very early) but Doug has warned me not to use the Congo as the basis for any additions, this has to look at least from a distance like the J on the monitor. (and therefore like the studio model in the initial post with the Universe Class Reconstruction Project Banner)
Nice toolkits here:
Ship chart
http://jbobroony.deviantart.com/gallery/
http://jbobroony.deviantart.com/gallery/#/art/Federation-Starship-Recognition-Cart-378349286?_sid=34baef4e
http://jbobroony.deviantart.com/gallery/#/art/Excelsior-type-starships-379125048?_sid=2680551c
New Toolkits--look at the great saucers--scroll down
http://ststcsolda.proboards.com/index.cgi?board=ststcsoldashipsg&action=display&thread=25&page=4
http://gundam1701.deviantart.com/art/U-S-S-Enterprise-NCC-1701-ver-Gar-339423852
http://gundam1701.deviantart.com/art/Mega-Starship-Parts-Layout-Final-377534810
http://gundam1701.deviantart.com/art/Starship-Parts-Updated-Layout-343403470
