3DTech Flooor Tests
soulburn3dsoulburn3d1 Posts: 0Member
edited October 2016 in Work in Progress #1
Here's a few starship hull tests I've been working on. I made these images to explore variations in greebling and hull plate shapes and configurations. The tests are a little less practical and a little more abstract, but they have been really helpful, and should be a great source of inspiration and practical experience the next time I decide to make a full fledged 3d model of a starship or space station. Parts were modeled in 3dsmax (many wires were done using my wirebundler script), rendered with brazil, some was painted in photoshop (so the image isn't 100% 3d, but the majority is), and many patterns were inspired and produced by Darktree, Bercon Noise and Filterforge procedural patterns.
More to follow in the coming week.
- Neil
http://www.neilblevins.com
Post edited by soulburn3d on
«1345
  • L2KL2K0 Posts: 0Member
    pretty cool :)
  • ulkeshulkesh0 Posts: 0Member
    Those would make for some cool wallpapers. :)
    interesting work.
    Cool stuff.
    I like...:D
  • hazendhazend171 Posts: 0Member
    :D
    Very nice.
  • tobiasrichtertobiasrichter333 Posts: 0Member
    Cool stuff, Neil - as always. IA’d suggest maybe a few less pipes in the underlying sections and a little more "tech" gadgets there.
    Tobias
  • soulburn3dsoulburn3d1 Posts: 0Member
    Thanks everyone, glad you dig them. I have another 3 to 4 images on their way, some of which are a little less pipe centric (and one that's pipe crazy <G>). I'll post em soon.
    - Neil
    Oh, very nice stuff. I'm very interested in that wire bundler script, think I'll have to DL it from your site and play around a bit. Out of curiosity, are the procedural patterns you referred to build into Max? I'm not familiar with them, but it's been a while since I was really digging around in the UI.
  • BasillBasill172 Posts: 0Member
    Those are awesome. Especially for the "greeblie" minded. :D
    Thanks guys.
    Jedilaw, afraid those are all separate plugins. Filterforge and Darktree are for purchase, the Bercon Noises are a free plugin. Max's built in procedurals aren't terribly powerful sadly, almost nothing is new in that area of max since max 2 :(
    - Neil
  • fractalspongefractalsponge254 Posts: 1,088Member
    Wow, that's amazing.
    So, if I'm reading this right, the large panels and the circular greebles are hand modeled, the small panels are a procedural texture (normal map?), and the wires are procedurally generated by a script?
  • SyklonSyklon0 Posts: 0Member
    What everyone else said, that's awesome. I especially like all the subtle details on the plating, if that's all procedural its seriously impressive.
    Welcome on board Neil!
    I know your website from a looong time. ItA’s good to see a wip from you here. ;)
    soulburn3d wrote: »
    Thanks guys.
    - Neil
    Ahh, I see some examples on your site. So are you using those noise maps as an inspiration for the pattern of the paneling, or have you incorporated them in as bump maps? The panels look modeled to me, and god knows I've spent a lot of time yutzing around with paneling (not as much as Fractalsponge, but then, who has?), so if those results can be obtained with maps instead of modeling I'd be very interested to know about it.
    EDIT: Just skimmed your bio. Without getting too fanboyish, allow me to say I am a HUGE fan of all things Pixar, so having someone from that hallowed land visit us here at SFM is definitely a treat.
    Wow, that's amazing. So, if I'm reading this right, the large panels and the circular greebles are hand modeled, the small panels are a procedural texture (normal map?), and the wires are procedurally generated by a script?
    Thanks Fractal, your work on this forum has been a huge inspiration to me, so I'm honored that you like my work. Your breakdown is pretty accurate, although the procedural bits have been hand modified after the fact to make them a little more organic. So for example, the smallish plates are several procedurally based 3d patterns, mostly based on Worley Noise, then I bake that out and add paint on top, then used as a bump. So I'm using the procedural to do the heavy lifting of adding detail, and then I use hand paint to avoid it looking to uniform or repetitive. The wires are made using a script I wrote called wireBundler for 3dsmax, here's a more organic example of what it can do...
    The script is more of a placement tool than a creation tool, all the wires are hand made, then layed out with the tool. Then again, I bake them to meshes and modify them to make them look nicer.
    Thanks Syklon, as I mentioned, it starts off procedural, but then I add a handpainted layer ontop. While I love procedurals, it's faster to get exactly what you want where you want with hand painting :)
    Starship wrote:
    Welcome on board Neil! I know your website from a looong time. ItA’s good to see a wip from you here.
    Thanks. I've actually been a lurker here for several years, this is just my first project that really seemed right for a board like this.
    Jedilaw wrote:
    The panels look modeled to me, and god knows I've spent a lot of time yutzing around with paneling (not as much as Fractalsponge, but then, who has?).
    Some of the panels are modeled, mostly the larger stuff, also, mixing modeled panels with bump mapped panels helps to confuse the audience, so people can't be sure which is which :)
    As for my employer, glad you're a fan. I just wish we did more scifi stuff :D
    - Neil
    l
    What, Wall-E wasn't enough? :) Incidentally, did you work on the Omnidroid in the Incredibles?
    BTW, if you guys are doing Cars 2 and Monsters, Inc 2, and Toy Story 3 (okay, that's one's done), somebody needs to poke Brad Bird in the ribs and get him to work on a sequel to the Incredibles. I know, I know, he's doing M:I4, but surely he'll have some downtime on set to work on a script...
  • HelotHelot391 Posts: 164Member
    Amazing stuff! Glad you joined up, love your site btw.
    soulburn3d wrote: »
    You're too kind - thanks for sharing this stuff - I now really want to make more panels :).
  • tobiantobian226 Posts: 1,600Member
    Superb! I sure could use a plugin like that to do pipe bundles, I end up doing all that kind of thing by hand. The mix of procedurals and modeling has an absolute sweet spot, fantastic work! Inspirational stuff, and ditto fractalsponge.. I think I will be hitting the surface of my station again soon! :D
    Ah, I see, gives me some new ideas for what to do on the hull plating for my Leviathan, thanks. Looking forward to seeing the rest of these you've got coming.
    At this rate we're going to see a giant surge in paneling activity on these forums :)
    Jedilaw wrote: »
    One robot film is never enough :)
    Jedilaw wrote: »
    Nope, I was doing environments for that film primarily, although I did model/shade/light all of the robots in the supersuit sequence in E's lab though.[/QUOTE]
    Jedilaw wrote: »
    Brad doesn't respond to poking :) But he knows we'd all love to work on it if he gets the itch.
    Thanks, I appreciate it.
    By all means, I'd love to see em. :)
    Thanks dude, I try to do my best to use the advantages of both ways of working. Of course, it's a lot easier when your surface is flat :)
    Cool, I've seen some of your ships too, good stuff, I've certainly been inspired these past few months by all the work on this forum, I'm happy to be able to contribute something to the mix.
    - Neil
    All great for Borg designs. Any thoughts to adopting your wares--having them taper off so as to do ready-make antenna farms?
    Yep, I wish I had the luxury of flat areas to work on, sure would be nice! :D
    Here's another two...
    - Neil
    well.. Thats inspiring! way excellent!
  • SgtChainSaWSgtChainSaW0 Posts: 0Member
    Amazing stuff. Love the balance between large and small details. Seem like everytime you look at it you seen more and more detail. Amazing.
    That really is rather impressive :D
    Thanks guys.
    SgtChainSaW, trying to find the right balance between large and small details is probably my most important goal in these images, glad you've found it successful.
    - Neil
    really cool, the style suggests something of massive scale to me, it would look great on a high detailed homeworld ship, or some other old school / book cover type design
