hey,
Could anyone provide a rundown of the common 3d model file formats. I know .mb is Maya and .max is 3dstudio but what are .Mod files and how do you use them.
Also what are the other formats out there and how do you convert between them?
I'd recommend just googling each format you have a question about. As far as I'm aware though, nearly every program reads .obj. As well, nearly every program has at least one proprietary format I think.
What program uses .mod files? Remember that nearly every game you encounter will have it's own set of formats.
I couldn't find out how exactly .mods are used. There are other types of files that use the extension including an audio format but I think they are for models in games. I was able to find a 3ds to .mod converter but not the other way around and I still dont know how one would directly edit one. I'll give milkshape a try and see what it can do.
I know that exists a free plugin for Milkshape, which can convert from nif, mod and sod to 3ds for example. Studio max can import 3ds files, so, you can play with the mesh.
Sometimes I do this myself, just to see the nif, mod and sod files better.
Already forgot: the plugin is available at chUmbaLum sOft
thanks guys, I'm going to try to convert with milkshape and see what comes of it.
Word of advice when using Milkshape to port models from one format to another. In my experience, most of the time Milkshape will cause a texture to light itself very brightly when it's not supposed to be lit up at all. There are also cases in where the entire mesh is mirroed and everything is backwards.
These issues are fairly easy to resolve when the models are imported into other model programs such as 3D Studio Max, but, when it's happened to me, I found it rather annoying and couldn't stand for it.
Just thought I'd let you know just in case you run into it and didn't know about it.
Also, if you import .mod files into MILKSHAPE, be careful, cause not always does Milkshape load the model. Sometimes it'll crash. Why, we've never been able to find out.
.mod could also be for the Starfleet Command series. I suggest the Assimsoft milkshape 3d importers/exporters. Also, try opening the file in wordpad. It might have a file header that would give you a clue as to what to open it with.
So I wasn't sure how to install the plugin for milkshape. I copied the ".dll"s into the program file folder. They show up in the file menu under "import" and export like they should but when I attempt to open the files the program crashes.
any ideas?
Validating my first bit of advice: MOD (file format - Wikipedia, the free encyclopedia)
Lemme guess, the Neverwinter Nights option would be where you found it?
-Stefan-
Bridge Commander used *.nif format models
Star Fleet Academy used *.mod format models
Models formatted for these games would be for use in these games and little else.
then again I'm old ;D
any ideas?
