I like it but I think it's far too jam-packed. Spacing the Prometheus and Daedalus further apart and fixing the lighting should do the trick. Also you might want to check out the fact that you've got so much stuff in the background that it takes away the focus of the image from the actual ships!
its good... i agree that it is too cluttered in the background. i would take out the galaxy since earth is in our galaxy anyway(if the planet is not earth than dont worry about it) and if it were another galaxy, like pegasus, than it is too close. i would also tone down the green on the puddle jumpers. they are a bit more grey in the show. the green planet is strange (if the main planet is not meant to be earth, than it is fine) the only other thing that i would do is turn the prometheus 90 degrees towards the camera and space it farther from the daedalus. its a great image. it would probably take me weeks (if i could do it at all) id probably have given up tho. sorry for all the complaints but if it helps you make a less cluttered and more dramatic image than it is worth it. keep up the good work!
Great work though!
