Modeling Help
juise15juise150 Posts: 0Member
I have a model that is giving me a hard time on the render process. I have tried many things including flipping polys and merging. Do you have any suggestions on how to fix this problem?
Post edited by juise15 on
    Hm, to me it seems, that you have some overlapping polygons.
    Try to weld all points, that are at the same position, that should do it.
    Another source for this problem is probably a copy of the mesh at the same position!
  • juise15juise150 Posts: 0Member
    Here is another view
    Welding just screws it up
    I got a similar thing in Maya, a couple of warning messages from my renderer suggested something to do with normals (it was a while ago, I can't remember the exact error) but manual normal adjustment didn't help. In the end, I just had to remake the object.
    What sort of object is it? Poly? NURBS? etc.
    What modification have you done to it since creation?
    alibobba wrote: »
    Looking at your mesh it's really nasty. It might be easier to rebuild it (since it's not a complex object) rather than fixing it.
    To be honest with you, its a TrueSpace conversion. So I didnt even build the original. Actually it is the Tactical Station from the Galaxy Class Bridge on Star Trek
  • todaytoday0 Posts: 37Member
    You could always manually draw back in those missing polys
    That would explain it, conversions can really screw meshes up sometimes. I remember a conversion I did ended up turning a mesh inside out and back to front, really bizzarre.
    It may be easier to do a new mesh, in Max it would be fairly easy to do as a loft object, I'm not sure about Lightwave, not really used it enough to explore it beyond poly tools.
    If I draw polys to replace the bad ones, they still look wrong
  • TheGreatRajaTheGreatRaja171 Posts: 0Member
    try running the Unify command on it. you may have some flipped polys.
    another idea would be to manually take and reform the tri's into quads
