3DPool table
seanrseanr1034 Brooklyn, NYPosts: 567Member
edited May 2021 in Work in Progress #1
This is starting out as a typical bar-type Valley coin-op pool table (sort of a cross between a Big Cat/Panther and a Dynamo):
I'm probably going to do a Trek version of a pool table using some of these parts, but this coin-op version will end up in a holodeck at some point.
Post edited by seanr on
Lizzy777wolfman
  • darkthunderdarkthunder398 SwedenPosts: 97Member
    Chez Sandrine maybe? 😆
  • seanrseanr1034 Brooklyn, NYPosts: 567Member
    It'll actually be a recreation of a league bar named Angry Wade's here in Brooklyn that closed down due to the pandemic. That bar was the only place around here that I could reliably get some decent games of pool in. :(
    darkthunder
    Lizzy777wolfmanpsCargile
    Lizzy777
  • lennier1lennier1732 Posts: 1,235Member
    edited April 2021 #6
    Blast from the past! Didn't you do a scene with another pool table ages ago?
    [Edit]Found it:
    Post edited by lennier1 on
    Lizzy777komaro
    Yep. That was sixteen years ago. LOL. This was the final version of that:
    That was based in a real bar in Virginia Beach, VA (the In-Between, the first gay bar I ever went to and whose logo I designed, but is now long gone).
    Lizzy777komaro
    BTW, I'm pretty sure I still have all the textures from that, but I'll likely only reuse the one for the chalk cubes.
    Would be a nice touch for something from the old scene to be reused in the new one.
    lennier1 wrote: »
    Like I said, probably just the chalk textures. The rest isn't up to my current standards and not worth the trouble to attempt to convert from trueSpace (and believe me, that's a lot of effort).
    Latest render, now using microdisplacement for the cloth and the floor in addition to the bricks:
    ashleytingerLizzy777
    Added the paint layers on the floor under the table.
    Lizzy777
    Update, rendered with the Cycles X development build:
    Lizzy777
    Building out the rest of the bar - the building shell has been there for quite a while, but now filling it in:
    Lizzy777
  • rwkingrwking185 Posts: 171Member
    I'd shoot a rack of 9-ball on that table.
    seanr
    edited May 2021 #15
    Fixed the ceiling hight and a bunch of other related things (these are just from the viewport, not full renders):
    Lizzy777
    Lizzy777
