Should have started this thread a couple days ago, but I've been working on this as a standalone object since it's in two bridges (I'm generally doing that with all the more complex movable objects):
Certainly not perfect, but I'm calling this final for now.
I actually made one more edit after that render but neglected to re-render it before pulling it into the Excelsior set.
Request: if anyone has any references for the armrest controls, I would greatly appreciate that. I've been able to find no shots showing them.
Thanks! 100% procedural. If you're a Blenderhead, the material is in use in the HAG Capisco download over in the releases forum. It's not as simple as just reusing it on any object - you do have to set up all your seams correctly and unwrap the mesh. There's quite a bit of trial and error involved, but I'd say its worth the effort for that reaction.
