3DEnterprising Images
evil_genius_180evil_genius_1802781 Posts: 10,401Member
I made some new textures for my TOS Enterprise model. When I first built the ship, I didn’t want to do any paneling or weathering on the textures. Well, I’ve changed my stance on that and I’ve done both paneling and weathering. The paneling is subtle, it’s only in the specular channel and I used small variations in shades of gray to make it subtle. The weathering, on the other hand, is more prominent. It’s in both the color and specular maps. I didn’t bother trying to recreate the weathering on the 11-foot model, instead I just did my own thing. I also tweaked my bussard collectors further and finally got them looking how I want them to look. After that was done, I decided to render some images.
I originally planned to do more than two images, but I wound up spending some time converting some of my older models to Lightwave 2018. This basically entails changing from the old style materials to Principled BSDF materials. Principled BSDF works much better with the rendering engine in Lightwave 2018. Unfortunately, when I change the materials, I have to reapply my textures. And, for materials where I didn’t UV unwrap the objects, I have to redo the mapping as well. So, it takes some time, to say the least. But, it was worthwhile as I was able to use my Starbase and Reliant-style ship for the second image.
Lizzy777Warp Propulsion LaboratoryFreakpubliusrBrandenbergLoophole
  • TralfazTralfaz405 Posts: 846Member
    I really like your first image with the very subtle textures.
    evil_genius_180
  • scifiericscifieric1076 Posts: 1,450Member
    This is beautiful work, Chris. Your new texturing helps impart a true sense of scale. Well done.
    evil_genius_180
  • ashleytingerashleytinger1455 Central OhioPosts: 1,019Member
    Oh wow. Love the subtle plating. it really adds to it without being in your face
    evil_genius_180
  • evil_genius_180evil_genius_1802781 Posts: 10,401Member
    Thanks a lot, everyone. :)
  • Vortex5972Vortex5972250 Posts: 1,150Member
    Looking good.
    evil_genius_180
    Vortex5972 wrote: »
    Looking good.
    Thanks. :)
    Here's a quick one I did when I got home from work this morning.
    rojrenLizzy777FreakashleytingerscifiericpubliusrWarp Propulsion LaboratoryBrandenberg
    That is beautiful work, Chris! Well done!
    evil_genius_180
    Thanks a lot, Eric. :)
    scifieric
    That looks great dude. And you're right, from this distance those panel bolts are barely noticeable... oh wait. :p
    evil_genius_180
    Thanks Vortex5972. :)
    scifieric
    I decided to do another render with the Starbase 15 scene, but with different ship and camera positions and different lighting.
    Lizzy777FreakashleytingerWarp Propulsion Laboratorygmd3dBrandenberg
    Excellent work!
    evil_genius_180
    Great image. I've always liked that ship as well.
    evil_genius_180
    Thanks guys. :)
    Wow really nice work!
    evil_genius_180
    Thanks a lot, ashleytinger. :)
  • Hunter GHunter G1681 Posts: 513Member
    She looks soooo good! Subtle paneling is indeed the best paneling
    evil_genius_180
    Hunter G wrote: »
    Thanks Hunter. Yeah, I don't like that in your face paneling. In my opinion, it should disappear under certain lighting conditions.
  • gmd3dgmd3d249 DublinPosts: 132Member
    Nice work Chris, fantastic to see your still working on the Enterprise and other Trek designs. still my failing as a modeller is textures.. top work
    evil_genius_180
    “You become responsible, forever, for what you have tamed.”
    Thanks a lot, Ger. Good to see you back around this way, buddy. :)
    gmd3d
  • BrandenbergBrandenberg1650 CaliforniaPosts: 1,930Member
    Crap. I hadn't looked at the finished work for a while and totally missed this. I HAVE to learn that paneling. I have been trying.
    Anyway - incredible work.
    evil_genius_180
    Thanks man. I can screenshot my settings when I get home.
    There's a couple sceenies showing the material setup. It's really a pretty simple node setup. A lot of the subtlety is in the specular map itself. The color variation in the panels is pretty subtle, which is what sets the specular levels. The roughness and metallic settings also make a difference, as they determine how the light is distributed along the object.
    Lizzy777
    Thank-you. Downloaded and saved. I recognize that specular map. Just like me, you use the same map for most of your saucers?
    evil_genius_180
    Sometimes I use the same maps, especially if I want to maintain the same look for a fleet. However, that was a brand new map I made for that ship. I made the panel pattern by selecting polygons onto a flat cylinder that I added geometry to in Lightwave that was the same size as my saucer. Then I rendered that with an orthographic camera and used that render to make my maps.
    It is very generous of you to share all that data, Chris! Well done!
    evil_genius_180
    scifieric wrote: »
    I figure out a lot of stuff through trial and error. If I can help people skip a few steps that I had to take, I'm all for it. I'm sure that most people on here would do the same for me or at least pay it forward.
    Brandenberg
    Indeed, for sure.
    I do the same thing.
