3DStargate Kawoosh
Mr. WildeMr. Wilde180 Posts: 120Member
edited June 2019 in Finished Work #1
After years of on and off tweaking, I finalized the Kawoosh animation. It's all done in LightWave 2018 using a complex nodal displacement setup, with some post processing in After Effects.
It's the very same principle as in the breakdown video I did years ago. The secret lies in tweaking the displacement until it looks and animates like a water surface. The rest is created by reflections of a proper background image, and a luminous surface behind the event horizon.
Cheers,
Rob
Post edited by Mr. Wilde on
FreakLizzy777
  • FreakFreak690 Posts: 3,860Member
    Very nice.
  • NutsyNutsy1 Posts: 14Member
    Ah kawoosh I remember you....
    Very nicely done :)
    Your wormhole also is spectacular...
  • BrandenbergBrandenberg879 CaliforniaPosts: 1,358Member
    I'm blown away. I wish I could do that.
