3Dmedjai's Dumont....into Lightwave wip
mikalamikala176 Posts: 440Member
edited February 2015 in Work in Progress #1
Wow another great share by medjai!
Giving it a go on bringing it into LW.
So far it is going okay methinks.
Post edited by mikala on
  • trekkitrekki761 Posts: 1,295Member
    Very nice, but
    It lacks a few textures ....
  • evil_genius_180evil_genius_1802781 Posts: 10,401Member
    Looking great, Greg. I've been wanting to do this, but I haven't had time.
    trekki wrote: »
    That's probably why it's on the Works in Progress forum. ;)
    Yes I am still figuring out where to drop some of the textures in.
    Sadly I'm monolingual so having a bit of fun going through the surface names.
    She is a beaut though.
    I know what you mean about the names. The day I loaded it to see how it looked, I pulled up the surface list and thought, "This ought to be fun." ;) You could use Google Translage for the names you don't know.
    What can I say? I like the surprise when I hit the surface with 100 percent Lum and see what lights up!
  • medjaimedjai9 Posts: 0Member
    Hi Greg, looking great.:thumb:
    With the names of the textures if necessary i can help you.
    and as request, the orthos view.
    I can do with more resolution if you need
    trekki wrote: »
    Very nice, but
    the texture to these areas as trekki commented is the malha.
    Thank you medjai!
    The ortho's are great. Higher rez are always welcome!
    I may have to do some tinkering to get the honey comb pattern to work in LW.
    Right now I'm getting an odd offset happening.
    Escape Pods 12 and 13...where might they be?
    mikala wrote: »
    Thank you medjai!
    Escape pods 12 and 13 are at the back of the big pod
    This shot explains better where they are. :D
    I am well and truly blind!
    Thank you.
  • MadKoiFishMadKoiFish6465 Posts: 4,868Member
    Cool only thing I can point out is some of the smoothing angles are a bit strong. In max it is smoothing groups. I dunno if LW has this or if they can be set manually. Or if it is only a slider with edge angle detection only. It is mostly visible in that large opening on the saucer and the Sensor pits.
    I gotta get off may butt and make some scenes with this model as thanks for the release.
    Thanks
    I'll look into the smoothing angles.
