It's been a while since I posted anything, and this is something I've been messing around with for a while. I call it the Lassiter. Been using it to experiment with Blender's compositor (the drive plume) and Starfield and nebula courtesy of Gimp.
The Lassiter was my first attempt at a complete scene many years ago. I'm still working on this one, but I had to compare them...
And the original Lassiter ...
Here's another shot closer up with more intensity in the plumes. This is the Lassiter's star drive. The other engines are for higher g maneuvering, lift-off, and landing.
Oh, yeah. I'm trying for a more brutish, simple design. Heavy cruiser, planetary bombardment, that sort of thing...
The thrust affect is surprisingly goofy, from a modeling standpoint. 99.995% of the work is done in the compositor with blurs and glows. I then overlaid it multiple times on the black background to get the brightness I wanted. The really goofy part is the modeling. Imagine 40 or 60 spline curves coming out from the engine in a radial pattern. These splines are a pale blue. Next I added 4 white disks inside the splines and a long white tube about 4 units away from the engine itself.
For materials, I used pale blue with a decent amount of emittance (light emitting property in blender) and the disks and tube got a white material with the same emitter value. When the render part is complete, I get a bunch of bright blue stalks and white disks and a long white tube. Blender's compositor is used to create a heavy gaussian blur overlaid on a lower blur. I then added some glow effects and viola! The trick is to completely blur the goofy splines and such so that you don't see the sticks and tubes. You can overlay this image back onto the ship to get the complete picture. I took that into Gimp and overlaid multiple copies of the ship onto a black background until the glow showed up really bright like I wanted it.
I may have to do a tutorial on this...
Mach:thumb:
Grat ! Have to give it try by myself !
Really well done :thumb:
Cheers, S.
Mach:thumb:
Mach:thumb:
