it's quite a nice overall shape. i'll need to see more detail really. you might want to change the canopy style, the current single window in the centre of the fuselage looks a bit strange.
Sorry if it took a long time to post, but I hit a snag with the engines. The boolean on them was corrupted and I had no saved version prior to it, accept the very basic shape. So I started again (At least twice), but this time I stick with the original idea, to have kind of a part of it that is detach on the side. I think it's for the best, in the sens that the shape is more "together".
its an interesting design the engine pods seem a lil over sized tho
once you are free from the tyranny of the rocket equation the thing you want to maximize is engine size(if rocket equation applies you want to maximise fuel tank size).
nice updates Komaro
that maybe if it wasnt startrek which this is based on his shuttle size is to small for the size of nacelles he has going on in my opinion the power core he has to put to thos engines seems like it would be to big to fit in its current set up
Update. Well for the size, there is also kind of a laser on the side that is house there, and it can also be used as a stabilizer to level a rapid descend (A bit why it's a drag on aerodynamic)
Thank you all for your kind words. This is it for that project, these are the last render. To follow, there should be 2 wallpapers in 2D illustrations in the finished section, eventually. I leave you with those and the reference page.
nice updates Komaro
http://www.3ddub.net/muse-shuttle/
