3Dplanet tryout
colbmistacolbmista2 Posts: 0Member
edited July 2013 in Work in Progress #1
found a nice tutorial on youtube thought id try it out i think i need to change some of the colors in the light rig tho
Post edited by colbmista on
    no suggestions?
    Overall ambient light is too high.
    Clouds on the dark side too bright.
    Atmosphere bubble much too big and should only be visible on the illuminated side.
    It looks like you forgot to make the star casting a shadow.
    Scale seems a bit off, if the earth like planet is meant to be in the foreground it should be bigger.
    What software did you use?
  • rojrenrojren2335 Louisville, Kentucky USAPosts: 1,980Member
    It's pretty nice, although the planet looks like it's surrounded by a gently glowing bubble. That's a pretty serious ring around the larger moon.
    max2012
