Directly inspired by the USS Vengeance from Star Trek Into Darkness, this is a slightly more traditional Federation Dreadnought (with 3 nacelles) geared for battle. I am experimenting with the very angular almost 'stealth' appearance of the ship. Still playing around with this so please keep checking back for updates.:thumb:
Model link:
http://sketchup.google.com/3dwarehouse/details?mid=a9ec2d241b289b51ee86e0e72754043
-Ricky
The whole design looks very good, is the saucer section inspired by the concept art of the Vengeance? It looks pretty similar.
Go ahead :thumb:
Yeah, I've been getting a lot of that reaction on this model. Responding to those comments, I've been working this morning on changing the shape of the saucer cut-out slightly so that it hopefully looks a bit less like the Trade Fed Battleship. The new saucer is shown on the left, the old one on the right. What do you think?
Yeah upon playing with it for a while now, I can see that that may indeed be the case. Here's another angle, hot off the press!
awesome grid lines and shape of glowing bits.
Now one idea might be a honking phaser cannon mounted between the ends of the saucer that was so fraking big and generated such a EM field and waste heat load it has to be mounted 'semi externally" to keep from frying the ship with EM emissions and waste heat.
Trek has never been big on 'spinal mount" weapons except for the revised 1710-1 d in the last TNG ep, but you could try it as an experiment.
The cannon could be mounted between the flanges on the front, and they could have big waste heat/coolant plasma vents angled back to vent coolant plasma (Possibly hydrogen collected by the bussards?) above and below the ship while not facing directly forward and making them a harder target. It might have to vent a few tons of superheat coolant as incandescent plasma whenever it fired that monster.
Excess EM byproduct from the cannon itself could be emitted above and below the actual weapon mount in the middle.
I think that one klingon vessel in tng, vorcha class(?), had a cannon for a nose so the idea could be given some trek validity.
Another option, a little less trekish but still valid could be to leave the saucer front as it but have those flanges generate a containment field that a huge amount of energized plasma (or for a real bang, anti matter based plasma. Oh my!) was pumped into and released at a target, sort of like a fed attempt to copy/improve on the romulan weapon seen in 'balance of terror".
I think that stabilizes the design a great deal.
Weeeell, yeah, ya got me! Keen eye there Saquist, I tip my hat to you sir. In my defence, it wasn't a case of being lazy. I genuinely thought the shape, with several modifications, would suit this overall design. In any case, even the sfx crew from the old star trek days were known to re-use parts etc...but thank you.
Actually, I must add a big thank you to everyone here who has commented and critiqued this design. Without your constructive observations and suggestions, this design would not have evolved as much as it has done. So cheers!:thumb:
Attachment not found.
The front view is the most interesting.
Damn good ideas, keep at it. The idea of a specifically designed warship having the biggest gun possible could be a good one.
You might want to add some sort of targeting scanners to the ends of the supports to make it look like a stereoscopic targeting system for maximum aiming accuracy, just an idea.
nice as this spinal mounted weapon is i think it was better when you just had a cylindrical bridge at the centre and a sliced saucer as you did a few posts previously.
very nicely textured but i think the texture should be higher resolution to avoid the graininess. nice two tone grey patterning on the lower hull at the rear.
Does need higher rez textures, but looking good.
