Hi all,
Here is a model I made of Luke's lightsaber from ROTJ. This was made as an excersise to speed up my modeling workflow.
Comments and suggestions are welcome. I suspect there might be quite a few accuracy errors, so feel free to point those out.
/Filip
light sabers could never work, first light cannot be confined to a beam and it will fly off at 3x10^8 ms^-1. second even if you used a retracting blade that pumped out plasma and even if you had a compact enough power source it would still me a more effective weapon if it just fired plasma "pellets" (which is hard to do as plasma will separate out due to the charges repelling each other) or laser beams. also just consider the situation, you have a light saber, i have a space fighter. when i am in orbit there is nothing you can do to attack me but i can drop kinetic projectiles on you! OR you have a light saber but i have a gun,you can kill me if i am within your arms reach but i can shoot you from range and your reactions are not quick enough to block the bullet/projectile/laser beam from hitting you.
anyway sorry about the rant, good model and texture.
Hero prop: http://i.imgur.com/zDtjGlj.jpg
Stunt prop: http://i.imgur.com/Xhya9xb.jpg
Thanks, I didn't know that! Looks like there is a quite big difference between the stunt and hero versions.
light sabers are a direct violation of everyting we know about light, it's not that we don't understand them, it's we understand full well they cannot exist! even if they could there are better methods of attack and defence that the energy could be used for.
did not notice in the film that luke holds a different useless device at all other scenes than the vader one, some people know some really random stuff.
Originally, George Lucas envisioned them in wide use. There's famous concept art of a Stormtrooper holding a lightsaber. (see attached) However, as he was creating the SW universe and deciding what fit where, he decided that lightsabers fit better with the mysticism of the Jedi Order, so he made them weapons exclusive to the Jedi, which made them fall into the Jedi's fantastic abilities and, therefore, need no explanation. So, no, they can't possibly work but that's OK because they're actually part of the Fantasy aspect of Star Wars.
