2DFalcon Class
Startrek91481Startrek91481171 Posts: 0Member
edited October 2013 in Work in Progress #1
Ok so Narsil Inspired me.
SPECIFICATIONS
Ship info:
Class: Multi-Role Interceptor
Construction Facility: Boeing Assembly Plant, Seattle, Washington, Earth, Sol Sector
Crew Complement: 1
Performance:
Cruising Velocity: Warp Factor 1.5
Maximum Velocity: Warp Factor 2 for six hours
Propulsion Systems:
Warp: Basic Matter/Anti-Matter Reactor
Impulse: (2X) Compact Fusion Impulse Reactor
Tactical Systems:
('4 Type VII Phaser Arrays
('2 Type IX Phaser Cannons
('10 Hard Point mounts for out-board ordinance:
A‧ A2A-114 A“CobraA” Fire and forget photon missile
A‧ B1B-2214 Quantum Dumb Bomb
A‧ A1B-009 Sensor Guided quantum missile
A‧ fC9C-445-J Photon Bunker Buster Sensor Guided
('1 Fore Torpedo Launcher
('1 Aft Torpedo Launcher
Post edited by Startrek91481 on
  • RekkertRekkert4102 Buenos Aires, ArgentinaPosts: 2,311Member
    It looks very cool and different, I love the modified arrowhead logo on the top view.
    I don't like the nacelles very much though, they look too Naboo-ish for me. ;)
    Also, I like the idea of the rotating joints, but they don't make much sense for warp nacelles, only for impulse engines. May I humbly propose to move the warp nacelles to be directly connected to the body, and leave the impulse engines alone on the joints?
  • BCBC0 Posts: 0Member
    Rekkert wrote: »
    I like the lines of the warp shuttle, though as I said it looks Romulan to me more than Federation. :)
    If the impulse and warp pods are combined like they are on the Romulan D'deridex it would not be bad having the whole assembly rotate, though the spikes would get in the way of any use of the engines as vectored thrust unless you intend for them to drive into the ground on landing or something. As far as I know of the only vectored thrust shuttle the Federation has so far is the Argo so there is probably room for another for use in fields that interfere with the usual antigrav systems, especially one with more range.
    Speaking of range, I would suggest more endurance and speed for the warp drive if it is meant for interstellar use since the travel time between Earth and Alpha Centauri at warp two is about five months (though the writers often ignore their own warp speed charts). On the other hand if it is just meant for high speed maneuverability in the same star system it is fine as is.
    trek shuttles are always a bit ugly and stubby, which i am not a fan of. however this craft looks quite good and i do like the rotating engines. the spike extending from their rears looks "nabooish" but also very good.
  • Startrek91481Startrek91481171 Posts: 0Member
  • NarsilNarsil0 Posts: 0Member
    I'm glad I was able to inspire you. :) I like that you added the impulse engines to the back of the nacelles. Maybe you could add some micro-torpedo launchers on her.
    I like the revised version. One suggestion: Unmanned combat vehicles are in vogue now, why not make an unmanned star trek combat drone?
    Also, a short duration vessel may not have bussard collectors as it's not meant for long range/duration use, so it doesn't need to gather interstellar hydrogen, It would likely, if it needed fuel, get it from a carrier/support vessel that might even beam fuel on board in a few seconds.
    ehem, i have already designed a "falcon class drone"here. i do not have a problem with you calling it a falcon but think you may wish to call the drone something else. a drone is actualy a very good idea though, i notice that the "nabooish" spikes are gone but the engines in their place look just as good or perhaps better. i can see what judge death is saying about not having bussard collectors but rather than remove them why not refit the whole ship for longer range longer term operations, maybe have a fighter capable of long range interstellar travel. aslo perhaps make the bussard collectors bigger and replace the two of them with a large one in the centre somewhere that then feeds the gas to the engines through pipes. overall quite nice.
    not to dump on your work or be a sheldon Cooper (God I hate people like that!) but......warp 2 maximum?
    on an interceptor?
    seriously, there are shuttles and transports that outdo warp 2 by a long shot. freighters can outdo warp 2, so, what is this going to intercept?
    given the huge weapon load and extremely low speed I'd say this was more of an assault ship than an interceptor, like it's meant for attacking planetary targets or bases, immobile targets essentially.
    it could also be a defensive unit carried by a carrier to trouble spots and left to defend immobile assets like planets and bases. at warp 2 it would need a carrier to get anywhere in time.
    BTW, your missile looks a little mundane, you might want to jazz it up a little. Here's a good design for a futuristic missile:
    http://www.youtube.com/watch?v=qsh8lZtLpT8
    on an interceptor?
    The warp 2 capability is more or less for emergency situations. This is a carrier based fighter.
    thanks everyone for the comments. Judge Death unfortunately my computer won't run the video, but I appreciate the suggestion.
