3DIRML Enterprise E lighting
LonewriterLonewriter236 Posts: 1,080Member
edited February 2013 in Work in Progress #1
I got my hands on IRML's Enterprise E mesh and I am trying to light it but haven't had much luck. I'm using Lightwave, any help would be appreciated. BTW, I can't give this mesh out to anyone, sorry. Thanks Dave for letting me use it.
Post edited by Lonewriter on
  • BlueNeumannBlueNeumann845 Posts: 1,398Member
    The current lighting makes it look like a toy package, which I like! You should extend the background and do a text mock-up on the side!
  • LonewriterLonewriter236 Posts: 1,080Member
    A text mockup? You mean like if this was going to be a model box?
    Yeah yeah, "Real lights and sounds!" "May contain Borg" etc.
    That's a good idea.i might try that sometime. I want this render to look like it is a still from a movie. I deleted the scene and started over.
  • Chris2005Chris2005679 Posts: 3,097Member
    From the shots he uploaded on his own thread, I thought the lighting rig looked perfect...
    However, I'd try to give it some lighting to blend it with the background... first, I'd make the planet side of the Enterprise darker, and then give it a faint blue cast...
    Have you rendered out an Ambient Occlusion pass that you can composite into the shot?
    AMD Ryzen 9 5900X
    Thanks, I started over, I'm using an Earth mesh instead of a bg image. Also, the Lightwave version didn't come with any exit or lighting rig, only the ship lighting.
    Here's a render I threw together, not the Enterprise E, but nevertheless...
    AMD Ryzen 9 5900X
  • trekkitrekki981 Posts: 1,435Member
    lonewriter:
    What have you done, that you have received the Enterprise of IRLM? :)
    Keep going Lonewriter you'll get it!
    I'm still working on it, thanks.
