3DUSS Challenger from Dennis Bailey in C4D
trekkitrekki822 Posts: 1,299Member
edited January 2013 in Finished Work #1
Hi all
I have the great object from Dennis Bailey converted to C4D.
And here it is ....
Post edited by trekki on
  • Chris2005Chris2005654 Posts: 3,093Member
    Now this is a cool design... I see it incorporates features from the JJ Enterprise, while still maintaining that lovely classic overall design... this should be the Enterprise in the new movies...
    ... and it's a lovely picture.
    AMD Ryzen 7 3700X
    240GB SSD, 500GB SSD, 1TB HDD, 4TB external HDD
  • Dennis BaileyDennis Bailey404 Posts: 54Member
    Nice image.
    Interesting treatment of the nacelle domes. Do the textures and lights convert that way, or do you tweak it?
  • StarshipStarship388 São Paulo - BrasilPosts: 1,918Member
    Great rendering Trekki!
  • trekkitrekki822 Posts: 1,299Member
    Thanks all.
    Dennis,C4D has set the lights so the bussards. Is this ok? Do you have more tips for me?
    regards
    I'm mainly curious - how does a C4D conversion work? Is it mostly automatic?
    The domes on the LW version, of course, are a great deal more opaque - they're set for translucence without much transparency, with a very high specular setting to create a kind of "frosted" effect.
  • tekkon7tekkon761 Posts: 0Member
    This is really good. I like the terrain too, getting it to look rugged an can be really time consuming.
  • evil_genius_180evil_genius_1802825 Posts: 10,409Member
    That render rocks. (no pun intended ;)) I love that background and Dennis's model rocks. The setup and lighting really pull everything together nicely.
  • LonewriterLonewriter235 Posts: 1,073Member
    Nice, I like this mesh.
    Thank you all for the comments
    tekkon
    The terrain is a texture, sorry.
    Dennis.
    C4D can invite LW Objeke. The textures agree unfortunately not nearly all. The materials are all wrong. Transparency must allso be slightly frosted, right?
    Greeting Trekki
  • nightfevernightfever360 Posts: 584Member
    Hey trekki, great achievement on the lighting. A little bit of indirect light from the asteroid would make it perfect.
    I like the background.
    Hi Dennis.
    I have changed the texture and material of the bussard.
    Is that ok?
    Trekki
    Attachment not found.
    how did you make the rocks below and the background?
    Just beautiful! Nicely done!
    Is it possible to make the material translucent with little or no transparency?
    Hi Dennis
    I must try it, good idea.
    regards
    here it is. the material is a subsurface Scuttering. Better ??
    Rendertime fast ....
    I guess what I'm curious about is if there's a way, as in LW, to not have the "fan blades" visible behind the dome. The idea is that they only matter in animation, when they pass between the light and the surface of the dome.
    Ok,
    next one
    New Bussard material.
  • Ian KeldonIan Keldon0 Posts: 0Member
    ^That is just about perfect...maybe a touch more glow, but just a touch!
    You should do some orthos (fore, aft, side, top, bottom)
    Here are the orthos ...
    have fun
    Yes, that bussard material is a great improvement.
    On those orthos, are the port (red) navigation lights not working?
    Hi Dennis.
    Yes he is working. In a animation sequenz as blink light.
    trekki wrote: »
    have fun
    Many thanks!
  • LatosLatos335 Posts: 0Member
    I know i've seen the background before! I think you should credit the guy!
    http://www.moodflow.com/
  • TralfazTralfaz405 Posts: 846Member
    I took a look at moodflow's site and he has some great images. Went through the 9 pages that were available and I didn't see the image in trekki's picture. Could have missed it though.
    Al
    Here it is.
    I must have missed it completely! Problem with getting old...
    Like I said though, moodflow does some amazing stuff and I saw 1 or 2 images I wouldn't mind using as a background!
    Thanks for that link Latos.
