Help with smoothing problems...
I've been trying to contact DJ Curtis, but the only way to contact them, as far as I know, and per the readme file, is via bc-central, which doesn't allow new registrations, at the moment...
Example:
Nothing I do will get rid of these bends... welding vertices, etc.
Post edited by Chris2005 on
AMD Ryzen 9 5900X
    Somtimes imported meshes behave very weird in max 2012.
    Select all the geometry in the object, and detach it to a new object. That usually fixes "stuck" smoothing groups for me
    Making a new smoothing group for them doesn't help? Try putting a STL check modifier on top and then collapsing the mesh.
    I just used NifSkope to convert the model, and voila, perfect, at least compared to the Milkshape conversion...
    AMD Ryzen 9 5900X
