Granted the model is in Lightwave format, but does anyone know if they were accomplished with properly textured objects themselves, lens flares, or...?
The CG Voyager model:
I've been trying everything, spheres with falloff maps for the opacity, I've tried lens flares, but they vanish as you slow obscure the light, which doesn't happen with the method used on the actual CG Voyager, as I watch the episodes... trying to find a 3ds Max equivalent of what was done...
I'm trying to figure out how to make them look like this on Flat Eric's model... but I'm not sure how they were achieved on the actual CG model in the series...
I can give it a try...
Yea, if they're far above the surface, so that they don't get cut off by the geometry of the hull...
Here is a glow test:
I decided to go with finalGlow, since standard Max Lens Effects Glows would require me to set a different material ID for each color light...
Voyager model by Flat Eric.
having said that I imagine this was done just by applying blurs to a nav light pass
In max, you can set the same thing, but it cuts off the flare, at certain angles... if it intersects the hull...
Interesting idea... I think I have it just about solved, using actual glows...
If they're being used as part of the directional lights, they shouldn't vanish, until completely out of view, like in the show... not just when the omni light source goes behind the object...
The directional lights are visible, even after the source object passes behind the hull...
For example, if I used flares in this shot:
That top green light on the saucer wouldn't be visible, as far as a flare would be concerned... but I want it to be visible just like that, until the actual sphere object itself is obstructed, but if I put a omni light close enough to the hull, at the same XYZ place as the object, so the flare doesn't appear to be floating above the hull, it will vanish at this angle, even though the light sphere geometry is still visible... and if I set it to show behind objects, it will show behind the object, but at certain angles, it will get cut off by the hull, even if the flare is completely within view, and it doesn't look right, I'm trying to get it to look like it does in the show, and behave the same way, so far the glows seem to be doing the trick.
The flare is visible when the light reaches the camera. If the light is obstructed, there is no flare.
Unless you are talking about the bulb object thing on the hull - in which case you should just be applying the glow/flare to the object or it's material, and not a point light source
though you're right it is better to apply glow to the material, or like I said do a nav light pass and blur it
Exactly.
Well, right now, the passes I usually do, is the regular render pass that is displayed, along with a velocity pass, and a self illumination pass, to help make lights stand out better after the motion blur is added in AE... I'm working on a video right now...
I created mine on the NX-01 for example and other star-ships using spheres with fall-off maps (middle would be white, while the outer glow would be green or red (depending on the color) and it would have a slight black edge to it - kinda liked the effect.
The bloom effect you are talking about for example can be done (it's essentially what they did when we saw a warp flash from the nacelle of the warp grill that wasn't seen in the camera angle).
In 3dsMax a specialized plugin that properly simulates flares, glows, etc. for example can do this.
Not sure about LW, however I think it always had better control over such special effects... or they could have done it in post production
