Still keeping with the Avatar theme I have continued work on my ESA solar explorer, which has now been repurposed as my RDA Supply Ship the 'ISV Eclipse'
It basically consists of an oversized lander capable of 100,000 ton drop to a planetoid surface. The mothership is being built around it.
Here are some WIP shots and clay renders.
Built in Google SU8, clay renders in Thea, illustrations in PS CS5
Sketchup is doing pretty well, have all my layers and components nice and tight so no struggle so far.
Anyway the mirror is pretty much done, took so long as I had it done a few hours ago and I accidentally exploded its group crashing sketchup and loosing the file!
had to make it again which was a pain in the arse as its all modelled no textures so all those beams you see criss crossing the surface are actual geometry!
Still need to work out how the lander will attach/detach as the ship is basically built in a straight line with the lander connection the forward section with the protective mirror. I think ill have to construct some sort of lattice cage around the lander so when it detaches to de-orbit the ship will still hold together.
just out of interest, what kind of braking method do you envisage for this orbital lander to employ, the numbers involved in terms of momentum must be pretty epic!! :D
Not sure yet, the large thrusters used for the accent back to orbit can be flared a few times I guess, parachutes maybe?
I havent decided if it goes up and down once or can make multiple trips to the surface. I think im going to go with once to help with the design issues.
If thats the case it will have a disposable heat shield and parachutes with extra thrusters. It takes off again with the landing gear and can be refurbished for later missions.
Its not as big as it was in the illustration. If you look at the new clay renders you can see it in comparison with the valkiyre shuttles its much smaller now.
EDIT: You know I think there's currently enough technology to be able to build something like the lander today.
Really? Maybe the technology but never the budget or co-operation! It will weigh an absolute mental amount and need to ascend/decend under its own power?
Sorry for the poor quality will re-upload with a better image soon, but you get the idea!
Made a lot of progress as you can see, lattice structure holding the storage tanks to the engines is complete as well as most of the framework.
Still need to figure out how the lander attaches and detaches, will get on to that soon.
One thing about them radiators though - I'm no expert, just talking out of my ass here
If you arange them in pairs like that, wouldn't every radiator radiate nearly 50% of its heat to the other radiator in the pair?
Meaning that your 4 radiators are only dissipating very slightly more than 2 non paired radiators?
There is no convection in space so I thought this wouldn't be a problem as there is no medium for the heat to move between panels? I could be wrong but I think im right lol?
Your panels are radiating EM energy off into space - and a large part of that radiation hits the panel right next to it, heating that up. And the other panels is heating this one up. The greater the distance between the radiators, the less of the radiation hits the panels and you gain um...capacity to dispose of heat?
That's what I would guess anyway, also why the radiators (white panels) are arranged so that none face eachother here:
But maybe we can get nyrath in here, he knows this stuff
Edit:
Here's a crappy paint drawing:
dark red are your two radiators,
I only scribbled one radiator radiating.
green indicates "all energy is going into empty space", orange is borderline, i.e. "part of the energy radiated here is going into empty space",
and finally red where your one radiator is just heating up the other one.
Now if you add up all the green and orange for both radiators, you possibly end up having radiated more into space than if you had used just one radiator, but not much more.
But I could be wrong
Yeah I get it. I was just thinking about convection and heat and not the whole energy spectrum. I forgot to take into account EM etc ill reconfigure and see what I come up with.
So two single radiators edge on to each other is fine (like the ISV Venture Star). But a pair of dual radiators where the duals are face to face is defeating the purpose.
Graphic artist Myn.pheos used his 3D rendering package to find the best place to put his radiators.
http://www.projectrho.com/rocket/advdesign.php#id--Designing_with_CGI_Modeling
That is probably more work than you care to do, but it shows the basic idea.
Scientists actually used a 3D render package, using lamps to simulate head radiation in order to solve the Pioneer Anomaly
http://www.projectrho.com/rocket/advdesign.php#id--Designing_with_CGI_Modeling--Pioneer_Anomaly
There is Convection, Conduction, and Radiation, but the first two methods do not work in airless space.
In this case, "radiation" is more or less "shine like an infrared lamp"
Now, you probably know his already, but while the rockets are thrusting, the ship will act like it is standing vertically. The engines will be at the top and the whipple shield will be at the bottom. So the lander will be "dangling." I'd suggest it be attached by its nose to the ship's spine, with its tail hanging down, aimed at the whipple shield.
However, if you look real close at the Venture Star's radiators, you will see that each radiator is single-ply, not double-ply like you have it.
http://www.projectrho.com/rocket/realdesigns.php#id--Avatar_ISV_Venture_Star--Breaking_at_Alpha_Centauri
(look at upper right image)
Just make each of the two radiators single-ply and you will be golden.
The only possible problem I see with this is that you may be reflecting a percentage of your heat back into the radiator itself. At least this solution could be implemented fairly simply and without changing the design or profile that you've established so far.
Anyway, just a thought! Great work so far. Love to see these somewhat more reality based designs here on SciFi-Meshes.
as has already been said, looking awesome so far! keep it up!
The payload is generally the lander, inside this all the cargo is carried. In front of the lander are the hab modules that contain the living sections for the crew. They rotate inside the cylinders, think 2001 style and you will get it.
You can see a close up here on an earlier design, however the hab modules are generally the same http://www.scifi-meshes.com/forums/attachment.php?attachmentid=91387&d=1310322964
http://www.benprocter.com/avatar/vehicles/
