After a long Absence from my 3d home away from home I have decided to make my return with a new model. A ship from my own universe (Made using a Roleplaying Engine I created.), the Solarius Class Supercarrier.
Name of Class: Axxab Industries Solarius Class Supercarrier
Hull Type: Supercarrier.
Weapons:
PRIMARY: 4 Torpedo Launchers (Rated, 250 Gigatons)
++++40 High Energy Particle Beams (Rated, 5 Megatons Per Second)
SECONDARY: 20 Light Launchers (Rated, 1 Gigaton, each is a 10-Cell Vertical Launch System.)
++++100 Beamers (Rated, 20 Kilotons Per Second)
POINT DEFENCE: 100 Laserlight (Rated, .05 Kilotons Per Second)
Drive: Advanced Drive (400 Gee Acceleration)
Sensors: AEGIS Sensors (Range: 6 AU FTL Realtime Sensor, .25 AU Cloak Penetration Range)
Crew Count: 15A’000 (Minus Pilots and Maintenance Crew)
Crew Quality: Elite
Ship Quality: Best Quality
Tech Level: Tech III
Hangars: (Total Capacity, 1420 Squadrons, 17040 Craft Total.)
120 Superheavy Hangars (60 Ravenswords, 30 Carnadons, 30 Reapers)
('500 Heavy Hangars (400 Scythes, 100 Thunderheads)
('800 Medium Hangars (600 Medium Fighters, 200 Medium Bombers)
Crew and Briefing:
('5 Large Briefing Rooms
Launching Methods:
('4 Internal Launch Decks
('6 Drop Chambers
Pilot Quality: Elite
Total Cost: 142A’545 RP (Resource Points.)
So far. In total. All 20 Light Launchers have been added, as have the 4 Torpedo Launchers and the 4 Internal Launch Decks.
I'll be watching its progress.
Now to resume trying to find decent/cool turret references.
Work on the Point Defence Turrets.
While a good idea Aresius trying it proved too much of a pain in the rear. The Main Hangars went strange when I tried. But just under her nose (her big massive nose) on the ventral surface I found the room to fit the sixty doors (and even internally detailed tubes.. though that consists only of rails)
The Primary Weapons, larger than they should probably be strictly speaking.
I do, in fact the weapons currently on it didn't really fit the high-tech design look I was going for they've been scrapped from the model (but saved for use elsewhere of course) and are in the process of being replaced.
Point Defence Laserlights (Closed)
Point Defence Laserlights (Partially Armed)
Point Defence Laserlights (Armed)
Youtube of the Arming Sequence
Todays work
The almost final version of the model itself.
