I had a brainstorm the other day. This is a new type of weapon. Although it looks like a conventional pistol, the ammunition makes it very special. On Jupiter, there exists metallic hydrogen and metallic oxygen. Inside the bullet, both are encapsulated inside pressure spheres. Once the bullet hits a target, the tip sends a small charge through the bullet. The spheres combine to form a water jet. The jet shoots forward into the target. It could also contain just metallic hydrogen or oxygen only. Both are highly flammable.
Anyone that has seen a water knife knows this can work. 100,000 psi water cuts through steel like a hot knife into butter. I haven't completely worked out the specs on this, but I imagine it would be highly effective on almost anything.
looks a bit much like a regular gun...
It's an interesting concept.
No. This is Sci-fi. The metallic hydrogen and oxygen would be encapsulated somehow inside the bullet. Once it hits the target, it would 'break' open causing damage to said target. It wouldn't even need to be the whole bullet. A small amount would work just fine. If the thermal transference freezes the target, in most case the next bullet would shatter it. The bullets would be more or less safe until fired at something.
And Locke....the hydrogen and oxygen could be compressed from other sources. I just used Jupiter as an example of naturally occurring materials.
