I've seen work on real vehicles recently that put a bug in my head. Electric motorcycles biggest enemy right now is drag. The standard upright configuration isn't ideal. So I had the notion to try my hand at something at least a bit more streamlined. It's not finished, still need a few suspension parts, battery pack, hand controls, and such. It's far enough along that I wanted to get some feedback and show it off.
The body is hinged so that part of it can slide forward for easy entry and exit.
Which has nothing to do with your design. Your modeling is good, and your surfacing is interesting. I'd be interested in seeing anything else you did with the concept. It still doesn't say "motorcycle" to me, but that's me... and, apparently, Colb, who thinks it looks like a go-kart. :cool:
Tugar: neat concept. looks very retro, though, not really "streamlined."
As for some one that does, I would just like to say the only reason EV's aren't more popular is because all the designers keep putting dinky power packs and worthless motors that can't tote the load in them. But I have Practical EV building exp (yes Tuger, I will give you pointers if you need them when the time comes to add those things to your drawing). I've made more than one EV Dragster that humiliated a Big block so fast it's owner started kicking his car and crying.
As for range, its all a mater storage vs consumption. Last year I started work on a 64 ford econoline van that will be able to go 1500 miles between recharges. Its going to be propelled by a NetGain Warp9 electric motor and power will come from an Lithium Ion battery back made up of 6,800 3.6v 2.4ah cells. The only thing holding this wonderful road trip from Seattle to Los Angeles is the guy building the power controller array.
And I might point out that none of the vans internal space has a single battery in it. They are all contained in protected chambers down below where things like fuel tanks, drive line, and waisted space once existed.
So back onto the topic at hand.
Tuger, first. 2 wheels in front, 1 in back, else wise it will flip over every time it make a corner (see Top Gear - Reliant Robin video). Once you got that fixed I'll help you place the motor, power pack, controllers, and electrical brakes along with anything else ya want to know where it goes.
It's actually the 'bi' bit in bike and bicycle that designates two wheels. Motor unicycle, bicycle, tricycle and even quadricycle could all technically be shortened to motorcycle (something with motor and a number of wheels), while bike is a short for bicycle (so, two wheels). Dictionary definition is often a powered two wheel vehicle, but many include three-wheelers in some capacity.
Semantics is not the issue here though. The issue is you trolling again and everyone being sick of it.
Probably just model. If I can scrape up the cash, a decent motorcycle minus fork, and a VW front suspension, who knows?
