the thing with v'ger is you don't really want to be building the whole thing, it was never built like that originally
the scene where you see all of it in the directors cut is a bit lame - TV quality effects, and a bad impression of v'ger's size, it just makes v'ger very underwhelming
what I would do is only use that to give you an idea of where the pieces are in relation to each other, then build it and render it the way it was originally in the movie, only then can you really recreate v'ger, rather than something that looks like it's from B5
can't help you with refs sorry, but I think I saw shots of the v'ger model under construction, so maybe you could look for those, or maybe someone knows what I'm talking about and can post them
If you can't find good references for textures and details, then I suggest cross-referencing with similar models from other movies to fill in the blanks. Alien and Independence Day come to mind.
I have references to V'ger. Some of the stuff ranges from images shown in the TMP movie adaptation comic, actual pic of the model, design stuff from some of the books. (I gave the creator of the Bridge Commander model some of this stuff) and if I could be of assistance please let me know.
Never thought anyone would be crazy enough to attempt a build of this beast (except for the crew at Foundation for the Director's Cut of TMP, that is)! I don't think there's any way to represent the true level of detail that went into the physical V'ger model. It's just too massive and clear references are hard to come by. I seem to recall seeing a photo of John Dykstra standing next to the model. I don't think it would be much help when it comes to texturing your model, but I'll look through my photo files to see if I can find it.
My suggestion for the textures would be to take a more organic approach. Yes, V'ger was a machine, but so many of the details have a flowing, curved, organic feel to them. Perhaps a texture that looked like skin stretched over its hull might work better. It would also have to be an extremely clear, hi-res texture map that could be tiled seamlessly, and you'd have to tile it many times over. V'ger was so big that the details on its hull aren't noticeable until you got right on top of it. Think of it like looking at a skyscraper from 1000 yards away; it's color is uniform and details are impossible to spot. As you move closer by, say, half of each distance until you're standing next to it, more and more detail comes into view.
I've downloaded your model and textures. If you don't mind I'll play with it a bit to see what I can come up with. Should I happen upon a potential solution I'll post some images here. In the meantime, please don't stop working on this. It's an ambitious project, a good test of your skills (and patience). Keep us posted!
[email protected]I am really happy to hear that. I need to get better programs, as the ones i am working with don't allow for high poly models. It was all I could do to get the model small enough to work with in the Program I have (DoGA Series L-3 and Metasequoia). Would love to see the results of the tweeks.
I stumbled across this looking for stuff on V'ger. I don't know if this could help either. This is an actual rendering of the model used onThe Director's Cut
I am currently working on an update to the V'ger Model. With the help of many of you, I have been able to get it far closer to the mesh that was used in the Director's Cut Of ST: TMP than the first attempt. I don't think I did a half bad job considering the year old programs I have to use, lol.
here are the shots of the model... i have included a render of the original model for comparison...
Here are pics of the finished mesh. I am going to try and get it posted here. It will also be posted on www.trekmeshes.ch and In the resource area of Foundation 3D.
This is looking great, but I'm still not sold on the texture of the main hull. V'ger was gigantic, so from the distance in your images its hull would look nearly smooth. Have you tried tiling the material map a bit more and reducing the "Bump" settings?
And here are a few further references for V'Ger, in case you don't have them already:
http://www.startrekpropauthority.com/2010/01/star-trek-tmp-vger-spock-mindmeld-model.html
http://startrek.propworx.com/2010/07/12/behold-the-mighty-vger/
The Second Picture is also from the CG Model. The artist who did these worked on edit and says he will try to show other renders of V'ger
Here is a link to the artist Steve Burg
Nice picture, can really use it, thanks.
thanks.
New pics showing progress.
