I've been thinking of some uniform designs and I would like some feed back. Because I'm posting them here on Sci-fi meshes we'll just pretend they are for some sci-fi project.
This is like the BDU. This style would be available in other colors and camo patterns. My wife is helping me put this together in RL.
This is the garrison uniform. It is for the executive officers. The Army, Navy, etc would each have different colors. You'll notice the Imperial officer's cap. It is just a place holder for the actual cap which I have yet to design.
Any suggestions for improvement are appreciated.
These look pretty darned good. Very much more 'present day' and militaristic than your colourful starfleet design... Utilitarian, I think was the word I was looking for.
1. A design that overcomes the problems of BDUs and ACUs.
2. Something that looks less military and more civilian.
As far as goal 2 I went with simple solid colors to avoid using camo. The reason is, people are much less comfortable around someone decked out in full camo. The solid colors give it a less military feel. Also the primary purpose of this uniform is not tactical, it is functional.
Also it is designed to be worn with three different types of footwear. Black combat boots, the tan combat boots the army uses, and brown hiking boots. This flexibilty allows for people to still use this uniform even if they don't have the same footwear. Allowing hiking boots to be used also allows for a more civilian appearance.
The top uniform also is designed to be basic. It's function for specific situations can be modified by vests. These vests would be function specific in design. So for going to a class, one could wear the "Academy Vest"(or some other name). If one was going out for shooting practice they would swap for the "Tactical Vest."
The second uniform is all miltary and designed to give that impression. I wanted something that looks good, but also looks a bit futuristic.
There is a third class of uniform, the Parade uniform but it's not ready yet. That third one is designed to look modern,yet reminicent of the mid 1800's
Here is what I have of the Parade uniform so far. You can expect it to change a bunch before it's done.
Here is the start of the female Parade Uniform.
What are you planning to do with the real-life version?
The US (not counting the Navy) military has gotten away from this lately, because we're cheap.
we just use the tan service uniforms, unless the situation calls for camo or jacket/tie. it is cheaper
