XYZ movement problem with 3D Max 2009
Dr LeeDr Lee2 Posts: 0Member
Okay... spent today working on a mesh, only to have the XYZ move symbol start playing me up. When i turn the object into a poly to work with it, the XYZ symbol has in the last hour or so decided to stop being displayed aligned with the XYZ planes..... and when i try and move the symbol with the Vertex's selected, they just fly off in random directions...
the problem i'm having is that i've not knowingly changed any settings....:confused: The worst thing is, the mesh i'm working on needs to be complete in a couple of days:rolleyes:
Thank you in advance to anyone who helps :cool:
Post edited by Dr Lee on
    There should be a dropdown box somewhere on the top left saying something like world, gimball, parent, ...stuff like that.
    Check that world's selected (check in all subobject modes as well, you can change the setting separately for those)
    Thanks Melak... though it seems to have decided to fix itself without me doing anything *Is Confuddled*
  • MadKoiFishMadKoiFish9842 Posts: 5,334Member
    bug
    restart max and it will go away. or SHOULD.
    It worked, thanks :D
