Ive recently learned how to create an awesome phaser effect in 3ds Max using a particle system, a line, and several omni lights. Here is the test render:
http://www.youtube.com/watch?v=drY58D_3-UM
But here's the problem. I can link the line (as a whole) that the particles follow to the omni light coming from the phaser's starting position, but is there any possible way to link one point to one omni light, and the other point to the other omni light? Because I cant seem to find a way to do it.
Thanks in advance,
-Toa Kaita
That's real easy to do...create a "Hose" object, select your two omni lights as binding objects, and set the tension to 0.
