OK I've tried searching here and on the web but to no avail. I've tried messing with volumetrics, volume lights etc... but can't get it to work. Can anyone tell me how to create engine glow like fractalsponge!?
I must be an idiot but I tried volume light amongst others, but my results looked pathetic. Could you give any insight on the setting of such a simple "stretched omni, volume light?" I spent some time trying out many settings and could not get anything close to the look of fractals image!
make an omni light and stretch it (scale) then make a volume light effct and tell it to use the omni light... tweak the settings until you have something you like - fractals looks pretty much like the default settings.
Could you link directly to an image of fractals? can't find one with an engine glow following that link :S
I've found one of the disadvantes of using omnis + volume light to be the angle of the light cone. at best, you'll get a straight one, mostly though one that grows larger as the distance increases...nerver liked the look of that.
OK Coolhand your nonchalance is understandable now. After some more tweaking tonight I got much better results! I spent 2 hours last night with not much better results than the previous image??
Any other lighting tips would still be appreciated though!
Thanks again.
OK so here's what I get compared to fractals. that's the point of the question I can't seem to get anything close to the look of fractals image!?
Thanks
BTW thats Fractals MAX 6 ISD model.
Judging the cone from Fractals lights, he used spotlights.
