So I've been making Johnny 5 for the past few days and I've come to my first wall. I'm rubbish with texturing and lighting and I haven't the foggiest how I'm to make the LED lights in his "mouth"
I tried doing a google search but that didn't bring up anything. Tried searching the forums here, but the search function wont let me use the term LED saying it's too short or common.
I tried using some simple glass shader with a point light in it, but that looked horrible. Any help would be greatly appreciated.
Is there a reason why you can't just use a texture of LED's like in the above images? I had to make some LED readouts and found that the easiest way is to just sample images. You can even mix and match to make different symbols.
It's always helped me looking at a picture to identify exactly what I want to achieve:
When you take a closer look there isn't much more to it then using a fallooff or gradient to fade from bright red to a White or yellow in the middle.
A red glow could also contribute to making it appear bright instead of just a solid color
Here's a quick test I did in max:
