Here's the easy explanation. Draw splines that connect with at least four points, then the surface modifier will work. My best advice for spline caging is to plan ahead very well, otherwise when you get to a certain point you get stuck with stuff that is 3 node and have to monkey around to get it to work, and then it never quite looks right.
