I'm assuming picking the PAL widescreen preset with a pixel aspect ratio of 1.4 is fine as it will give me my anamorphic stretch correct?
Yes with those camera setting you should get the stretched look when you do a render but if you want to play with it in AE then render it out as an image sequence.
