Hello folks,
I am supposed to make images of several steel parts for work. Unfortunately, I'm somewhat stuck. I cant get neither the bumpmap nor the reflections right. I've tried several different approaches using max' cell, smoke, dents, noise and mixtures of those maps with standard scanlin/max textures and vray materials but nothing comes even close to the real thing. I've made a photograph so u can see, what I need. I seriously hope anyone can help me. I'm desperate
Thx so far,
-MerlyN-
CG Education
Just add grime.
--edit-- A couple more tutorials to look at:
3DTotal Tutorial
3d Tutorial
But they dont give any hints for scratched and bumped steel surfaces. oo
Here is the best I've been able to produce so far. As you can see, it's nothing like the original. The bump and reflection maps just dont look right
maybe you can do something with it . . .
like use this for diffuse, and edit it for bump and spec
Instead I'd use specular maps, as they'll produce a nice glimmer as the light hits the metal. The only thing you could use the bump mapping for are the slight scratches and dings in the metal, but I think that could be better illustrated with a slight grunge map in the specular level or mixed in with the diffuse map.
And this for the specular level and bump...
Hope this helps
@Ramiel I think ur maps are quite good. made these results with them and a raytraced reflection map with falloff. I think its getting there. Have to tweak the lights a bit, though. Will do that tomorrow.
@gallion311 No, without bumpmap the surface just looks too flat. But thanks anyways
@backstept As your maps is nice, too, its producing too brushed looking surfaces. But I might bring it to use in another project. Many thanks for ur help
