Stargate Hyperspace Tunnel
Scorpion222Scorpion2220 Posts: 0Member
Hi, i want to ask you if anyone know how to create a Hyperspace Tunnel like in Stargate sg1 in Cinema 4d? Does anyone have a Tutorial or a tip? i searched but found nothing useful. Thanks
Post edited by Scorpion222 on
  • SGA-3DSGA-3D0 Posts: 0Member
    Well, I created this effect in Max by using a simple procedural noise texture and stretching the UVs along a cylinder to give the stretched effect. A larger cylinder was created similarly, with another noise texture applied for the starfield.
    The other question is are you doing an animated tunnel or a still shot cause if your doing an animated one there is a tut for LW that shows how to do a wormhole and it could be moded to be a hyperspace tunnel.
    Tut link
    wormhole
  • Scorpion222Scorpion2220 Posts: 0Member
    Hi, thanks for your replies. yes i want to do an animated tunnel. Where can i find the tutorial? i searched the net but maybe use wrong keywords for search.
    HAHHAHAHA a duder the word wormhole is the link :D
    hehe:thumb:
