Maya 8 question
ElowanElowan0 Posts: 0Member
I have access to Maya 8 which I use for mesh conversions (or did) but this latest version doesn't give me the option of exporting to .obj; .max as did the older version. Is there a plugin for that purpose? I tried exporting to dxf and then loading that file into MAX. BZZZZT!
Can you tell I don't know diddly about Maya?:confused:
Post edited by Elowan on
  • gonk droidgonk droid0 Posts: 0Member
    window/settings & preferences/plug-in manager
    scroll down to objExport.mll
    tick off the loaded option
    Open Maya and select Window > Settings/Preferences > Plug-in Manager.
    objExport does not export OBJ formatted curves, surfaces, smoothing groups, or point group materials. It also does not support NURBS. Use the MayaToAlias plug-in for scenes that contain NURBS surfaces.
    Curses, you beat me to it, Gonk Droid. I shall have my revenge! Have a cookie.
    it's my jedi-like reflexes.
  • ElowanElowan0 Posts: 0Member
    gonk droid wrote: »
    Du'oh! Thnx:thumb:
    D.M.J. wrote: »
    G'dye? That is -- where do I find said plugin?:)
    I appreciate your help. What I don't appreciate is Maya's (apparently new) inability to export a complete mesh in formats other than ige or whatever.
    Oh well. DE can't do it either even with Maya on board.
  • LennOLennO5 Posts: 0Member
    Elowan wrote: »
    huh? Sure it doesA…export plugins pretty much haven't changed since v1 or 2, except for newly added formats.
    LennO wrote: »
    The latter plugin doesn't do it either. As I said - I'm a Maya Doofus.
    use the modify/convert option to make your scene all polys
    load the objExport.mll option in the plug-in manager
    then choose file/export - click the little option box to specify grouping and to make sure you're in the right format
    that should be it.
    gonk droid wrote: »
    that should be it.
    Ah so! Many thnx.:cool:
    That seems to have done it,
