360 Degree Star Field
I'm trying to create a 360 degree star field. I've downloaded panoramic star fields, but when I render them as a spherical environment there's pinching at the top and bottom. Does anyone have an effective method for doing this? Thanks!
Formerly furswift
  • japetusjapetus2012 SeattlePosts: 1,248Member
    Dunno if it's what you're after, but back in the day I used to just put tiny particle spheres on a huge sphere and use those as stars. If you are using 3ds Max, it has a starfield render effect in video post.
    Warp Propulsion Laboratory
    You could also try unwrapping your sphere differently, the pinching you are getting is from a spherical unwrap.
  • count23count23314 Posts: 730Member
    Use a Quadsphere and you shouldn't have any issues, UV and Icospheres when unwrapped "pinch" at the north and south poles. Quadspheres don't.
    Formerly Nadesico.
