On the subject of the Falcon, in the UK there is currently one of those magazines where you collect a part each week or whatever to build a model, and in this case it is to build a replica of the 32" Millennium Falcon (though this looks to be hybrid too, as it has the five landing gear configuration and is stated as being the TESB version), now usually I consider these sort of things to be pretty crap, but from looking at the shots of the finished product, and buying the (discount priced) first issue and looking at the pieces that came with it, I might just invest in this one, it looks pretty damned accurate and is a combination of resin and metal pieces I believe, with light up elements and interiors. The first issue also comes with a life sized blueprint so you could get an impression of the size of the completed asset, and map where your components go on the model. You should check it out.
Here's the link: http://www.buildmillenniumfalcon.com/?gclid=Cj0KEQiA6JemBRC5tYLRwYGcwosBEiQANA3IB9C8otclcY6O8kEn1w0laqX2EMYyk2eF6Zpcq__s1I0aAt9R8P8HAQ
Yes I know the Falcon has substantially greater marketing value than a trek model but still I can't see this being a very big market. I'd be very worried about this being cancelled to invest any money in it personally. But best of luck!
Yeah, it'll around Aï¿¡900, but spread over a few years it shouldn't sting so much, and will still be cheaper than one of those Master Replicas 1:1 scale studio models. That's the only worry, that the magazine set won't go the distance, but the business model for this sort of thing must work for them to invest so much in developing it. There's a subscription deal that ensures you get every issue, and you get a few freebie issues and gifts within that. Plus I'm sure they'd have a lot of angry customers if they decided to cancel the mag before completion.
As a side note, I have the deluxe larger Millennium Falcon that came out a few years ago that accompanied the 3.3/4 inch action figures, and this is going to end up bigger than that, despite the scale being much smaller. Interestingly enough that largest component in the packs above, the disc mount for the quad laser cannon is bigger than the one on the toy.
Looks like it is going to be a fun build.
I'll wait till my next delivery which will have a few more decent pieces (cockpit viewport structure and more I'm hoping), and will make a start. Want to work at it in significant chunks rather than a little bit at a time every other week or whatever. So after the next delivery we should see a bit of building going on in this thread.
From the quality of the parts I'm receiving and the paint job that they come ready applied with, I'm finally starting to lean towards the selected painting route, as in general the paint job isn't bad, and just a few areas could really use enhancement. I was worried the weathering on the hull plates would be inconsistent between parts etc, but they are proving to look pretty good all being said and done, good enough at least.
So the next hurdle is space to work on it, am working on that issue, so hopefully we should be able to see some updates with actual building action over the summer at some point. So stay tuned.
As for my own build, still on hold, need to secure that space to work in. Thinking of starting with a complete build of the cockpit seeing how I have all the parts for that, and it is a relatively small component. All about finding the time and the space to work in now. Will definitely have to look at Paragrafix for those cockpit interior components.
