Max and You
oldmangregoldmangreg198 Woodland Hills, CAPosts: 1,339Member
edited January 2014 in General Discussion #1
Anyone find a way to solve blinking lights not showing up when you render a video from Video Post?
Post edited by oldmangreg on
    Blinking lights? Can you elaborate?
    As I stopped using VP a long time ago and just use the Render Setup dialog...
    AMD Ryzen 9 5900X
    Chris2005 wrote: »
    My materials on the lights are set up with keyframes set on a loop. When I check did a few test renders of them on and off, they worked fine. In video post they worked fine as single frames (on and off) but I rendered an animation, they didn't work.
    I've had quality issues before with the render setup dialog when I rendered video so I haven't touched it in a while.
    UPDATE: I had to switch the Arch and Design material to an architectural one. Doesn't light up the area around the bulb but for now it'll have to do.
