In 3D Studio Max... I can't seem to figure out how to adjust the distance at which the light is cast... for example, a regular spot light I'd simply adjust the attenuation... but even with attenuation off, the photometric light only lights up a small area... this is the first time I've used these kinds of lights... looking at examples of photometric lights, they seem to be the best way to attain similar lighting spots as the actual CG model... unless it can be done with regular standard spotlights...
Post edited by Chris2005 on
if you want them to light up a farther distance then you increase the intensity
If you mean in the environment window, then no.
