Hey all,
I've been lurking on the forums here for the last few months, and the amazing work here has inspired me to get off my rear and do some modeling again. Let me start off with saying that I haven't
seriously modeled anything in about 10 years, so I'm re-learning as I go.
On to the ship! I wanted to create a smaller fighter-type craft that could fit in with the Corellian line of ships (Millennium Falcon, Corvette, etc). Hopefully I've gotten that down. However, I'm still tweaking the design as I go.
This ship is a 1-2 man ship (still deciding on that), that's primarily a heavy assault/bomber (think B-Wing).
Here are some WIP shots:
The cannons on the front are going to be replaced by recessed missile/torpedo tubes. I might put a turret on top for the main guns.
Starting on the engine greebles
More engine work
Some panel work
The Astromech is probably out of scale, and might be replaced with a turret
The main cabin will be resemble the Falcon's cabin, but scaled for 1-2 people.
Let me know what you think. I'm open to design changes/modeling tips.
Or you could do something like the EA6B Prowler and have two-by-two seating.
Thanks for posting.
Like everyone else said, that's a great start. I like the design and I like the greebles a lot.
It looked like a Tantive IV crashed into a ST saucer section at first, but I like where it's headed...
:thumb:
When I said it'd resemble the Falcon's cabin/cockpit, I was thinking of the exterior only. For the actual seating layout, I was leaning more towards a two-seater variety, with the seats in tandem. 1 for the pilot, 1 for the gunner.
Yeah, I'm not sold on the position of the droid. I'm leaning towards putting a turret there, but I was a little afraid that it'd look too derivative of the other Corellian ships. But then again, if a design works, why change it, right?
Thank you Jedi44!
Thank you! I'm finding I'm enjoying modeling the greebles most of all.
Agreed on the astromech placment. Scale is a little fuzzy at the moment. I'll probably tackle proper scaling once I get working on the cockpit.
Thank you for all the comments. Hopefully I'll be able to work on this a little more this week.
Decided to remove the astromech and put a turret in it's place.
Shot showing the scale I'm going for. I'll probably tweak it a little more as I begin to work on the cockpit.
As always, comments and critiques are welcome.
i'd easily see it be ejected to loose weight and gain agility.
or even better, those 2 rounded wings can become independent drones that will create diversion, or attract fire, allowing the bomber to do his job
Though, colbmista is correct, it seems a bit big for a fighter. Though, it could be a scout ship, or something along those lines.
I think I'll call it the YT-3600.
I think you need to define what exactly the mission profile of this class of ship is, and then the weapons and equipment etc will just fall into place. Has me thinking of the Skipray Blast Boat in terms of size and firepower, especially if you are thinking of putting additional fixed cannons either side of the cockpit. Though as has been mentioned I can see it in a bomber role as that would easily explain the disc shaped hull as a weapons payload bay. Coming along nicely.
Hmm.. not TOO much different here, right?
Wait... what's THIS?
OK, so this is no longer a "bomber" it's now officially a missile-boat. It's armed with 18 proton torpedoes. These missile bays are closed when in flight. They open for maintenance, and reloading. The torpedoes fire forward from the trench in the front of the ship. Hopefully that makes sense. If not, it'll make more sense when I actually model that part of the ship.
You won't normally see the exposed missile bay like this, but I was thinking ahead to maybe doing some hangar shots, with a few of these ships being worked on.
Next up is refining the turrets so they can actually elevate some.
As always, let me know what you think.
Good catch. I'll refine that, and put in some smaller gears.
I also re-designed the turrets. THESE should be able to elevate properly:
Next major step is coming up with the landing gears
