Hi all,
This is my new project I'm working on. I'm not exactly sure which era this ship belongs in. I've taken design elements from the Oberth class but I think the ship looks a bit swept back for the movie era. Anyways, here's what I've done so far;
Registry: NX-10001
Status: Experimental Prototype (Under construction)
Propulsion: Experimental Transphasic Warp Drive
Attachment not found.
do you have an idea scetched out on what transphasic warp drive is? or what it does??
looks great!
However I'd suggest, first and foremost, to establish an era for the ship. And then to further modify all of its aspects, adding more details and making it look more experimental. Right now it just looks like a typical ship with an added "roll bar" over the nacelles.
I definitively like it so far, but I know you can still make it much better.
The engines and pylons look perfect.
Keep in Mind Warp Propulsion Logic:
Many ships defy the logic of the warp field like Akira, Yager, Breen Firage and Birds of Prey because their overall shape does consolidate the ships mass with in a the bubble but rather forces warp field to stretch around odd shape extended pieces. Just like a magnetic field a warp fields strength lies at the heart and is strongest around smooth rounded shapes (again just like a magnetic field). Thats the purpose of the saucer to shape the forward bow of the field. Even better are ships like the Vulcan ships which give a shape that coutours the entire design. Like Voyager these should be Trek's faster ship as the temporal resistance is reduced while traveling through space time.
Apparently from my observations ships like the Prometheus and Dauntless have the pointed forward sections in order to creative a protective barrier around the ship with the deflector to penetrate a supposed "Time barrier" as I call it, aswell to survive the heat of slipstream entry and deceleration.
I would say this ship might fit into that theorem with the role bar helping to shape the field but like Voyager it should have field enhancers around the saucer (in this case around the role bar) to shore up the field in that potentially weaker area. I think the overall design could fit into the faster category with some tweaks.
Thanks again for all the comments. Yeah I've just finished work on my Sketchup Excelsior which has heavily influenced this design. I've decided to try and update the ship so that it looks like it belongs in the post-Nemesis rather than TMP era. It may not look that way now, but I'm gonna work on the texturing which should hopefully bring it up to spec.
First of all, I've changed the warp nacelles into something I hope looks a bit unusual and experimental. Again, they need a lot more surface detail but I'm posting it now to get some feedback on their general shape. I've also shown some different angles which show off the impulse engines. These were meant to show a kind of evolution from the Excelsior, where the engines tail off from the saucer section. These ones are much more 'built in' and have a crescent-shaped recess cut out between them, through which you can see a deflector crystal recessed into the secondary hull. :thumb:
One thing I just noticed. The registry, NX-10001, the number seems somewhat wrong.
The Excelsior (TMP-era) had NX-2000, but the Defiant (DS9-era) had NX-74205. So your numbering is somewhat.. misgiving.
Cheers for the feedback mate. Definitely agree with you about that upper pod. I think when its fully textured it'll look a bit less like a Miranda pod. At least that's what I hope...
The front of the nacelles is nice new look but I'm not sure of the segmented aft section of the nacelles.
Can you be a little more specific? Are the warp engines not even? Pod too low? In the words of Johnny-5; "Need Imput!!" lol!
Attachment not found. Attachment not found.
try canting the angle of the pylons for the upper pod so that from the side view it matches the nacelle pylons. The saucer details give the impression of a very small ship when compared to the rest of the ship. This may be rectified as you add details to the secondary hull. how big is it? The small neck combined with the fairly thick saucer reminds me of a "bobble head" toy. Especially in side on views.
Perhaps with the rear of the nacelles you need to look at ref images of various trek ships for inspiration to find a design solution that fits?
But with that first aft-view, I was somewhat surprised how slim the ship is. Maybe it's just the angle, but from that view, it seemed disproportionate.
I've also re-thought a bit about the back-story to go with the ship, which includes some details about it's new propulsion drive. I'm thinking that instead of 'transphasic warp drive' the ship is actually the test-bed vehicle for a 'jump-gate' drive. You see the same blue pattern on the front of the warp nacelles and the upper pod? This is meant to imply that the power generated by the engines is channelled through the upper pod to create a kind of hyper-dimensional gateway that pinches together two points in space and allows the ship to cross vast distances instantaniously. Kinda like the jump gates of Babylon 5. On it's test mission, the ship opens up a "Quantum Jumpgate" to the beta-quadrant but the jumpgate is unstable. The Hyperion disappears into the phenomenon and vanishes without a trace...
After the initial disaster with 'Quantum Jumpgate' technology, the designs are placed back on the drawing board indefinately. The spaceframe, however, is sound and the design is released into commercial production with standard warp drive. This production-version comes without the test-vehicle's roll-bar/pod arrangement.
