The Titanic: Lost in the Darkness team is having trouble converting my exterior models for Cryengine. My models are usually exported from Maya in FBX format, imported to 3ds Max, and exported from Max in 3ds format, and then the others import the 3ds format models to Google Sketchup, then, I believe, to Collada for use in Cryengine. However, when exporting FBX from Maya/importing to Max, normals/edges are messed up, creating lighting artifacts (dark and light spots) around various surfaces or openings. When the others import the models to Crysis, they are often further corrupted, having missing or flipped surfaces, or lighting artifacts. It's not on all models, but some. I'm not sure of the cause. I could use some help from people with more modeling experience/know-how, who may be able to convert/fix my models so they can be flawlessly imported to Sketchup/Crysis. Message me if you want to help in converting/cleaning up my models.
Thank you,
Kyle
I'll let him know...
The problem areas are outlined in green. He said sometimes it's worse. Boolean's seem to be where the worst happens. He said none of it appears in Maya, and it's fairly limited in the Max working window, but when rendering in Max or in the game engine, more of those trouble spots appear.
He said he should also add that the lighting issues on surfaces (darkened or lightened spots) can also appear in areas where he connected vertices, it seems, or occasionally where an edge was extruded. It's especially a problem in parts of the hull where he had to do more advanced work with the plating, but sometimes it just seems almost random with these trouble spots.
Here's a shaded wireframe of the hull.:
There were times that I needed to rebuild a few components, or weld vertices, or just to rebuild a few faces and apply the smooth again.
Hope that helps.
Its a mess to solve such things, but it would seem to our highly untaught minds on the matter that the advice given here is highly reasonable.
Reducing the number of programs the model goes through as much as possible is the best thing. It is often difficult to import models into sketchup, and they often require quite a bit of post-import work.
We've often had models that completely skipped the edge settings when they finally got into sketchup. Chain we've used is mostly (makeHuman/L3DT)>Blender>Sketchup or something like that. Might be that we've been able to skip middle step once or twice, but end result has always required a bit of extra work...
