Single File - 12K Earth Maps
Chris2005Chris2005675 Posts: 3,096Member
I've been able to find a night map that's 12K in DDS format, but I can't seem to find any others, I've looked on Celestia Motherlode, NASA's Blue Marble, all I find it huge resolutions, and they're split into tiles... I'm looking for one complete 12K map... of the Earth's surface, unshaded if possible... I don't really understand the difference between shaded and unshaded, but looking at the previews on Celestia Motherlode, I like the unshaded maps better, also a 12k cloud map, and specular map...
I'd something like the 32k sets for the maps, but they come in 25+ tiles... and I don't know how to put them together in a reasonable amount of time...
Thanks for the help...
Update:
Nevermind, my computer can't handle 12K, to say nothing about 32K, so I guess I'm stuck with 8K...
Post edited by Chris2005 on
AMD Ryzen 9 5900X
    for future reference when you get a new PC or something, I downloaded full 16k maps from there, you just have to dig a bit and you'll find them
    there's a good reason the big ones come in tiles, when you double the resolution of an image you quadruple the memory it takes to use it
    You're not a big one for patience, are you? It would probably only take about an hour or so to put the tiles together in their proper order. You can use pretty much any vector graphics art program to do it.
  • Chris2005Chris2005675 Posts: 3,096Member
    IRML wrote: »
    Yea, using 8K maps, after opening up the Task Manager in Windows, it already uses almost all of my 4GB of RAM...
    Not really, but I do my best to be. lol.
    AMD Ryzen 9 5900X
    I was about to upload the 21600x10800 diffuse and 43200x21600 cloud map, but I guess you won't have any use for those? :/
    Melak wrote: »
    Yea, not until I get more RAM... when I got my new mobo I was thinking of the now, and not the future, so I got a mobo with the RAM limit of what I had, which is 4GB, lol.
    AMD Ryzen 9 5900X
    You don't need more RAM. Just set up a really large paging file. ;)
    Besides, I've found that, even with larger amounts of RAM, the software doesn't always want to use it. But I also don't use Max, it might actually make use of more RAM than my software does.
    For my paging file settings... it says:
    Minimum allowed: 16 MB
    Recommended: 6142 MB
    Currently allocated: 4095 MB
    The settings are set to automatically manage the size...
    AMD Ryzen 9 5900X
    When I used to have RAM issues, I manually increased my paging file. It helps.
    General issues, or with rendering?
    Because if your renderer has to page stuff, it *should* be so terribly slow that you wouldn't want to render anymore. HDDs are orders of magnitude slower, both in transfer speed and response time.
    Melak wrote: »
    Loading, general usage, rendering issues. I was using an old AMD 533 MHz processor with 128 MB of RAM until a little over 3 years ago (my newer computer had died and it took me a while to be able to afford a new one.) The thing was continental drift slow anyway, so I really don't know of the paging file slowed anything down. However, since I didn't have enough RAM to do much of anything, it at least helped some. I got less "out of memory" messages with a larger paging file. ;)
    Melak wrote: »
    Some of my 3ds max scenes take upward of 1.5-2GB of RAM during rendering, like the shots for current TMP drydock tour, of course, most of the RAM usage comes from Prologic's drydock...
    AMD Ryzen 9 5900X
