Okay Blenderheads I need your help.
I have just DL the lastest version of Blender (2.60 Alpha),I know this version has the Cycles addon, but when I go into user perfances, then Addon and type Cycles. Nothing comes up.
I have checked user the Render addon (This is where it should be) and its not there as well.
I have even DL it onto an old laptop and get the same problem.
Am I missing something?
I would be greatful with any help.
Never mind "Cycles" is not part of 2.60, but will be in 2.61. (Due out next month.)
I found a none offical version of 2.60 that has it inculeded. If you want a copy it can be found at Graphicall.org.
just type "Cycles" in the search box. it will then give you a load a different version, just look for the one that suits your system and then install.
