Yes, you read it right.
I begun to play with Sketchup yesterday, 05:00 PM just to see what I can do with that pgm and, at 08:00 PM I got this.
Just a plain render and border cuts in the old Paintbrush. Kirkythea isnA’t instaled yet. For an exercise just to see where I can go with sketchup, in 03 hours, it turned out very well I believe. Opinions?
We would suggest smoothing and softening the lines on the curved surfaces... that would make it look even nicer... selecting eraser and holding in ctrl will allow you to do that to the lines rather than erase them... just dont remove the ones at edges between textures, since then you'll have trouble if you repaint it...
What you first need to do is download a lot of plugins. For example the Weld plugin, which lets you connect selected edges into a single line. That's one action -weld, say, three lines to eachother- versus twentythousandwhatnot actions: softening every line you don't want to be there. Check out my small tutorial in my sig, it'll help you out a lot
Nice Job, I was playing with Sketchup on my last tour of Afghan, an engineer was using it to produce images of enemy positions he was re drawing from satellite phots for briefings... for the life of us making a simple sphere was a nightmare. It was an old version though and we had no internet access to help us out. That said, this ship looks like a really good start, I look forward to your progress.
Hi Bro! How you doing?
Yes, I had to try.
I downloaded a few plugins, but still not experienced any of them. Therefore, didnAât known about the weld plugin. IAâll take a look in that tut too, for sure! Thanks!
Egeria hotkeys are always a good option. IAâll try the smoothed look later. Thanks!
MarkD when in home, try to play with sketchup. When you understand the workflow, youAâll see how simple the program is. About the sphere, you can use a plugin (simplest way) or do it by other way, not so hard in fact: draw two circles alligned by the center, one over the vertical and other over the horizontal plane. They donAât need to be the same size. Then, using the follow me tool, click in the face of the first circle and release the buttom, but move the mouse around the edge of the other circle. IAâll see the edge of the second circle turnning red and a sphere coming to life.
Uau!!! My last post in this thread was... 6 years ago!!
Well, IAâm trying to come back. I learnt a lot this year, when my interest in 3d got a revival.
To understand how to copy, move and align a object to a surface in Sketchup was a difficult mission, and it took me a lot of time to do it the right way. But IAâm pretty sattisfed in the end, cause I drew just one escape pod and the rest of them were a "copy, move, align" job made in a fast way. I present you the USS Theodore.
Yes, I had to try.
ItAâs good to see old friends like you too. :thumb:
